AnsweredAssumed Answered
Handling of onLoad and onLayerAddResults differences and Legends
Question asked by thoman999 on Oct 25, 2012
Latest reply on Oct 31, 2012 by thoman999
Hello all,
I've been trying to work through adding a legend to my app and have some confusion with the onLoad and onLayersAddResult event handlers. Right now the layers load but I never see a legend.
I'm currently loading the layers prior to the onLayersAddResult. Below is the init code.
Suggestions?
TIA
Tom
      function init() {
        var initialExtent = new esri.geometry.Extent(
                 {"xmin":-12665450.01,"ymin":3882991.10,
                   "xmax":-11985726.92,"ymax":4106191.89,
                   "spatialReference":{"wkid":102100}});
var lods = [ //Zoom levels allowed
           {"level" : 9, "resolution" : 305.74811314055756, "scale" : 1155581.108577},
           {"level" : 10, "resolution" : 152.87405657041106, "scale" : 577790.554289},
           {"level" : 11, "resolution" : 76.43702828507324, "scale" : 288895.277144},
           {"level" : 12, "resolution" : 38.21851414253662, "scale" : 144447.638572},
           {"level" : 13, "resolution" : 19.10925707126831, "scale" : 72223.819286},
           {"level" : 14, "resolution" : 9.554628535634155, "scale" : 36111.909643},
           {"level" : 15, "resolution" : 4.77731426794937, "scale" : 18055.954822},
           {"level" : 16, "resolution" : 2.388657133974685, "scale" : 9027.977411},
           {"level" : 17, "resolution" : 1.1943285668550503, "scale" : 4513.988705},
           {"level" : 18, "resolution" : 0.5971642835598172, "scale" : 2256.994353},
           {"level" : 19, "resolution" : 0.29858214164761665, "scale" : 1128.497176}
        map = new esri.Map("mapDiv", {
          extent: initialExtent,
    lods: lods,
   logo: false
//Load the elections Layer
        layer = new esri.layers.ArcGISDynamicMapServiceLayer(
            "http://gila-gis:6080/arcgis/rest/services/Elections/Elections2/MapServer");
        dojo.connect(map,'onLayersAddResult',function(results){
          var layerInfo = dojo.map(results, function(layer,index){
            return {layer:layer.layer,title:layer.layer.name};
          if(layerInfo.length > 0){
            var legendDijit = new esri.dijit.Legend({
              map:map,
              layerInfos:layerInfo
            },"legendDiv");
            legendDijit.startup();
       map.addLayer(layer);
createBasemapGallery();
        dojo.connect(map, 'onLoad', function(map) {
            //resize the map when the browser resizes
            dojo.connect(dijit.byId('map'), 'resize', map,map.resize);
    //after map loads, connect to listen to mouse move & drag events from coordinate tracking widget
            dojo.connect(map, "onMouseMove", showCoordinates);
            dojo.connect(map, "onMouseDrag", showCoordinates);
     buildLayerList(layer);  //Custom function to build layers into table prior to div placement
     //scalebar from scalebar widget
     var scalebar = new esri.dijit.Scalebar({
               map: map,
               scalebarUnit:'english'
Outcomes
