yanasdf789
how  to  get  the selected  feature  by infowindow?
Discussion created by yanasdf789 on Oct 24, 2012
Latest reply on Oct 25, 2012 by dawenx
how  to  get the   selected   feature  by  infowindow??
Just like  map.infoWindow.getSelectedFeature() in the    " esri.dijit.Popup"
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/>
    <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title>QueryTask with query geometry from another task</title>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.2/js/dojo/dijit/themes/claro/claro.css">
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.2/js/esri/css/esri.css" />
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.2"></script>
    <script type="text/javascript">
      dojo.require("esri.map");
      dojo.require("esri.tasks.query");
      dojo.require("esri.tasks.geometry");
      var map;
      /*Initialize map, buffer, & query params*/
      function init() {
        var startExtent = new esri.geometry.Extent({"xmin":-13165918,"ymin":3997806,"xmax":-13149675,"ymax":4007360,"spatialReference":{"wkid":102100}});
        map = new esri.Map("mapDiv", { extent: startExtent });
        //listen for when map is loaded and then add query functionality
        dojo.connect(map, "onLoad", initFunctionality);
        var streetMap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer");
        map.addLayer(streetMap);
      function initFunctionality(map) {
        var queryTask = new esri.tasks.QueryTask("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/1");
        var queryTaskTouches = new esri.tasks.QueryTask("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/1");
        //identify proxy page to use if the toJson payload to the geometry service is greater than 2000 characters.
        //If this null or not available the buffer operation will not work.  Otherwise it will do a http post to the proxy.
        esri.config.defaults.io.proxyUrl = "/arcgisserver/apis/javascript/proxy/proxy.ashx";
        esri.config.defaults.io.alwaysUseProxy = false;
        // Query
        var query = new esri.tasks.Query();
        query.returnGeometry = true;
        query.outFields = ["POP2000","POP2007","MALES", "FEMALES", "FIPS"];
        query.outSpatialReference = {"wkid":102100};
        var infoTempContent = "POP2007 = ${POP2007}<br/>POP2000 = ${POP2000}<br/>MALES = ${MALES}<br/>FEMALES = ${FEMALES}"
            + "<br/><A href='#' onclick='map.graphics.clear();getfeature();'>Remove Selected Features</A>";
        //Create InfoTemplate for styling the result infowindow.
        var infoTemplate = new esri.InfoTemplate("Block: ${FIPS}", infoTempContent);
        map.infoWindow.resize(275,190);
        var currentClick = null;
        // +++++Listen for map onClick event+++++
        dojo.connect(map, "onClick", function(evt) {
          map.infoWindow.hide();
          currentClick = query.geometry = evt.mapPoint;
          query.spatialRelationship = esri.tasks.Query.SPATIAL_REL_INTERSECTS;
          queryTask.execute(query);
          dojo.byId('messages').innerHTML = "<b>Executing Point Intersection Query...</b>";
        var firstGraphic = null;
        // +++++Listen for QueryTask onComplete event+++++
        dojo.connect(queryTask, "onComplete", function(graphics) {
          firstGraphic = graphics.features[0];
          var symbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new dojo.Color([100,100,100]), 3), new dojo.Color([255,0,0,0.20]));
          firstGraphic.setSymbol(symbol);
          firstGraphic.setInfoTemplate(infoTemplate);
          map.graphics.add(firstGraphic);
   function  getfeature()
      if(map.infoWindow.isShowing){
   alert("have the feature")
            var loc = map.infoWindow.getSelectedFeature().geometry;
   var lg=loc.rings.length;
   alert(lg);
          //  if(!map.extent.contains(loc)){
          //    map.infoWindow.hide();
    else
    alert("No the  feature");
      dojo.addOnLoad(init);
    </script>
  </head>
  <body class="claro">
    Click on map to select census block group that intersects the map click and all block groups that touch selected group.
    <div id="mapDiv" style="width: 850px; height:500px; position:relative;"></div>
    <span id="messages"></span>
  </body>
</html>
Outcomes
