Discover if a workspace is a geodatabase or a feature dataset
517
10-24-2012 08:19 PM
CarlBeyerhelm
How can I discover if the os.path.dirname of a feature class is a feature dataset or a geodatabase?  I need to generate a stand-alone frequency table of values from the feature class, but I can only create that stand-alone table at the geodatabase level, not at the feature dataset level.
Thanks...
JakeSkinner
Esri Esteemed Contributor
Hi Carl,
If you're iterating through feature classes within a geodatabase, it will only return stand-alone feature classes unless you specify a feature dataset within the arcpy.ListFeatureClasses function.  Ex:  (will only return stand-alon feature classes)
lstFCs = arcpy.ListFeatureClasses("*") for fc in lstFCs:     print fc
If you're not iterating using the arcpy.ListFeatureClasses function, you can use the describe method that Wayne mentioned.  Ex:
dir = os.path.dirname(env.workspace + os.sep + fc) desc = arcpy.Describe(dir) if desc.dataType == "Workspace":     <remaining code>
T__WayneWhitley
...think you can use Describe for this.  The datasetType property should return a string, FeatureDataset or FeatureClass, etc.
See the sample code here:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//000v0000002n000000
JakeSkinner
Hi Carl,
CarlBeyerhelm
OK, another rookie mistake on my part.
I'd been using the datasetType property without success, but the dataType property of os.path.dirname(feature class) distinguishes between a Folder, a Geodatabase, and a Feature dataset...which is what I needed.
Thanks to Wayne and Jake for nudging my pea-brain in the right direction...
