>>> import arcpy import glob, os #*********** PRINCIPALES VARIABLES ************* prefijo = "sde.SDE." Nommosaico = "mostest8" variable = "pslv" outLoc = "C:/IIE_Datos/Prediccion/Ejemplomosaico/test.mdb/" inNetCDF = "C:/IIE_Datos/Prediccion/Ejemplomosaico/MMOUT_DOMAIN1.nc" # Process: Create Mosaic Dataset arcpy.CreateMosaicDataset_management(outLoc, Nommosaico, "PROJCS['Lambert_Conformal_Conic',GEOGCS['GCS_WGS_1984',DATUM['D_WGS_1984',SPHEROID['WGS_1984',6378137.0,298.257223563]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]],PROJECTION['Lambert_Conformal_Conic'],PARAMETER['False_Easting',0.0],PARAMETER['False_Northing',-27.0],PARAMETER['Central_Meridian',-124.17],PARAMETER['Standard_Parallel_1',0.0],PARAMETER['Standard_Parallel_2',0.0],PARAMETER['Scale_Factor',1.0],PARAMETER['Latitude_Of_Origin',0.0],UNIT['Kilometer',1000.0]];-20037.7 -30225.3 149134210447.956;1 1;1 1;0.000001;2;2;IsHighPrecision", "", "") variable = "pslv" nc_FP = arcpy.NetCDFFileProperties(inNetCDF) nc_Dim = nc_FP.getDimensions() test = outLoc + '/*' r = glob.glob(test) for i in r: os.remove(i) for dimension in nc_Dim: top = nc_FP.getDimensionSize(dimension) for i in range(0, top): if dimension == "time": dimension_values = nc_FP.getDimensionValue(dimension, i) daat = "time '"+str(dimension_values)+ "'" print daat #nowFile = str(dimension_values) nowFile = str(i) testt = dimension_values.replace("/","").replace(":","").replace(".","").replace("'","").replace(' ','') print testt rast = "time" + nowFile #print rast # this will convert the FIRST time step in your netCDF file to a raster layer arcpy.MakeNetCDFRasterLayer_md(inNetCDF, variable, "lon", "lat", testt, "", daat, "BY_VALUE") arcpy.CopyRaster_management(testt, outLoc + rast, "", "", "", "NONE", "NONE", "") # Local variables: Build_Raster_Pyramids = "true" Calculate_Statistics = "true" # Process: Add Rasters To Mosaic Dataset arcpy.AddRastersToMosaicDataset_management(outLoc + Nommosaico, "Raster Dataset", outLoc + rast, "UPDATE_CELL_SIZES", "NO_BOUNDARY", "NO_OVERVIEWS", "", "0", "1500", "", "", "SUBFOLDERS", "ALLOW_DUPLICATES", Build_Raster_Pyramids, Calculate_Statistics, "NO_THUMBNAILS", "") # print dimension_values time '28/08/2012 12:00:00' 28082012120000 time '28/08/2012 12:00:03' 28082012120003 time '28/08/2012 12:00:06' 28082012120006 time '28/08/2012 12:00:09' 28082012120009 time '28/08/2012 12:00:12' 28082012120012 time '28/08/2012 12:00:15' 28082012120015 time '28/08/2012 12:00:18' 28082012120018 time '28/08/2012 12:00:21' 28082012120021 time '28/08/2012 12:00:24' 28082012120024 time '28/08/2012 12:00:27' 28082012120027 time '28/08/2012 12:00:30' 28082012120030 time '28/08/2012 12:00:33' 28082012120033 time '28/08/2012 12:00:36' 28082012120036 time '28/08/2012 12:00:39' 28082012120039 time '28/08/2012 12:00:42' 28082012120042 time '28/08/2012 12:00:45' 28082012120045 time '28/08/2012 12:00:48' 28082012120048 time '28/08/2012 12:00:51' 28082012120051 time '28/08/2012 12:00:54' 28082012120054 time '28/08/2012 12:00:57' 28082012120057 time '28/08/2012 12:01:00' 28082012120100 time '28/08/2012 12:01:03' 28082012120103 time '28/08/2012 12:01:06' 28082012120106 time '28/08/2012 12:01:09' 28082012120109 time '28/08/2012 12:01:12' 28082012120112 time '28/08/2012 12:01:15' 28082012120115 time '28/08/2012 12:01:18' 28082012120118 time '28/08/2012 12:01:21' 28082012120121 time '28/08/2012 12:01:24' 28082012120124 time '28/08/2012 12:01:27' 28082012120127 time '28/08/2012 12:01:30' 28082012120130 time '28/08/2012 12:01:33' 28082012120133 time '28/08/2012 12:01:36' 28082012120136 Runtime error Traceback (most recent call last): File "<string>", line 48, in <module> File "c:\program files (x86)\arcgis\desktop10.1\arcpy\arcpy\management.py", line 11034, in CopyRaster raise e ExecuteError: ERROR 001143: Background server threw an exception.
import arcpy from arcpy import env env.compression = "JPEG 75" env.workspace = "D:\\Tiles" indir = "D:\\Tiles" outdir = "D:\\TilesOut" rasterlist = arcpy.ListRasters("*", "ALL") for raster in rasterlist: inras = indir + "\\" + raster print "In image " + inras outras = outdir + "\\" + raster arcpy.CopyRaster_management(inras,outras,"#","#","256","NONE","NONE","8_BIT_UNSIGNED","NONE","NONE") print "Out image " + outras break
28082012120133
28082012120136
Friends,
I am using the following code ArcMap version 10.1, only I found the following error, I hope to guide me to give solution.
Runtime error Traceback (most recent call last): File "<string>", line 48, in <module> File "c:\program files (x86)\arcgis\desktop10.1\arcpy\arcpy\management.py", line 11034, in CopyRaster raise e ExecuteError: ERROR 001143: Background server threw an exception.>>> import arcpy import glob, os #*********** PRINCIPALES VARIABLES ************* prefijo = "sde.SDE." Nommosaico = "mostest8" variable = "pslv" outLoc = "C:/IIE_Datos/Prediccion/Ejemplomosaico/test.mdb/" inNetCDF = "C:/IIE_Datos/Prediccion/Ejemplomosaico/MMOUT_DOMAIN1.nc" # Process: Create Mosaic Dataset arcpy.CreateMosaicDataset_management(outLoc, Nommosaico, "PROJCS['Lambert_Conformal_Conic',GEOGCS['GCS_WGS_1984',DATUM['D_WGS_1984',SPHEROID['WGS_1984',6378137.0,298.257223563]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]],PROJECTION['Lambert_Conformal_Conic'],PARAMETER['False_Easting',0.0],PARAMETER['False_Northing',-27.0],PARAMETER['Central_Meridian',-124.17],PARAMETER['Standard_Parallel_1',0.0],PARAMETER['Standard_Parallel_2',0.0],PARAMETER['Scale_Factor',1.0],PARAMETER['Latitude_Of_Origin',0.0],UNIT['Kilometer',1000.0]];-20037.7 -30225.3 149134210447.956;1 1;1 1;0.000001;2;2;IsHighPrecision", "", "") variable = "pslv" nc_FP = arcpy.NetCDFFileProperties(inNetCDF) nc_Dim = nc_FP.getDimensions() test = outLoc + '/*' r = glob.glob(test) for i in r: os.remove(i) for dimension in nc_Dim: top = nc_FP.getDimensionSize(dimension) for i in range(0, top): if dimension == "time": dimension_values = nc_FP.getDimensionValue(dimension, i) daat = "time '"+str(dimension_values)+ "'" print daat #nowFile = str(dimension_values) nowFile = str(i) testt = dimension_values.replace("/","").replace(":","").replace(".","").replace("'","").replace(' ','') print testt rast = "time" + nowFile #print rast # this will convert the FIRST time step in your netCDF file to a raster layer arcpy.MakeNetCDFRasterLayer_md(inNetCDF, variable, "lon", "lat", testt, "", daat, "BY_VALUE") arcpy.CopyRaster_management(testt, outLoc + rast, "", "", "", "NONE", "NONE", "") # Local variables: Build_Raster_Pyramids = "true" Calculate_Statistics = "true" # Process: Add Rasters To Mosaic Dataset arcpy.AddRastersToMosaicDataset_management(outLoc + Nommosaico, "Raster Dataset", outLoc + rast, "UPDATE_CELL_SIZES", "NO_BOUNDARY", "NO_OVERVIEWS", "", "0", "1500", "", "", "SUBFOLDERS", "ALLOW_DUPLICATES", Build_Raster_Pyramids, Calculate_Statistics, "NO_THUMBNAILS", "") # print dimension_values time '28/08/2012 12:00:00' 28082012120000 time '28/08/2012 12:00:03' 28082012120003 time '28/08/2012 12:00:06' 28082012120006 time '28/08/2012 12:00:09' 28082012120009 time '28/08/2012 12:00:12' 28082012120012 time '28/08/2012 12:00:15' 28082012120015 time '28/08/2012 12:00:18' 28082012120018 time '28/08/2012 12:00:21' 28082012120021 time '28/08/2012 12:00:24' 28082012120024 time '28/08/2012 12:00:27' 28082012120027 time '28/08/2012 12:00:30' 28082012120030 time '28/08/2012 12:00:33' 28082012120033 time '28/08/2012 12:00:36' 28082012120036 time '28/08/2012 12:00:39' 28082012120039 time '28/08/2012 12:00:42' 28082012120042 time '28/08/2012 12:00:45' 28082012120045 time '28/08/2012 12:00:48' 28082012120048 time '28/08/2012 12:00:51' 28082012120051 time '28/08/2012 12:00:54' 28082012120054 time '28/08/2012 12:00:57' 28082012120057 time '28/08/2012 12:01:00' 28082012120100 time '28/08/2012 12:01:03' 28082012120103 time '28/08/2012 12:01:06' 28082012120106 time '28/08/2012 12:01:09' 28082012120109 time '28/08/2012 12:01:12' 28082012120112 time '28/08/2012 12:01:15' 28082012120115 time '28/08/2012 12:01:18' 28082012120118 time '28/08/2012 12:01:21' 28082012120121 time '28/08/2012 12:01:24' 28082012120124 time '28/08/2012 12:01:27' 28082012120127 time '28/08/2012 12:01:30' 28082012120130 time '28/08/2012 12:01:33' 28082012120133 time '28/08/2012 12:01:36' 28082012120136 Runtime error Traceback (most recent call last): File "<string>", line 48, in <module> File "c:\program files (x86)\arcgis\desktop10.1\arcpy\arcpy\management.py", line 11034, in CopyRaster raise e ExecuteError: ERROR 001143: Background server threw an exception.
