beanmj
DynamicObjectTracking Sample Issues
Discussion created by beanmj on Oct 23, 2012
I have compiled the DynamicObjectTracking sample project and added the toolbar item to my ArcMap 10.1.  When I run it the VW image shows up and starts running across my map, but my map blanks out to all white.  I am using the default StreetMap North America.mdx map.  If I change the code so it doesn't try to rotate the map, everything runs as I would expect (except the map is always north up).
I would think that map rotation should be supported.  Is there some setting or option that I am missing in ArcMap, or do I need a different map?
Thanks.
Outcomes
