eltopo
I can not save a "raster" output within a file geodatabase using Python
Discussion created by eltopo on Oct 22, 2012
Latest reply on May 28, 2013 by rzufelt
Hi friends,
I am using the command CopyRaster in Python, and I need to save the output raster file into a geodatabase that was previously created.
your path is:
outLoc = "C :/ Users/gualberto.hernandez/Desktop/MM5/VISUALIZACION/TEST 6/test6.gdb /"
and I'm stating the command like this:
arcpy.CopyRaster_management (nowFile, outLoc + rast, "", "", "", "NONE", "NONE", "")
Where "rast" is a value that will be changing, the script works iteratively.
I get the following error:
<class'arcgisscripting.ExecuteError'> Runtime error: ERROR 999999: Error executing function. Failed to execute (CopyRaster).
The strange thing is that if for folders stored in the raster perfectly,
Someone can suggest something to fix the error.
I will be awaiting your response.
thanks
eltopo
Outcomes
