Hi there
I have used Kernel Density tool from the spatial analyst tool on one of my layer in the map document. the result i assume is generated as raster data.on the ARCMAp i used identify tool to find the density at any point. However I wan to do the same job from client side using browser.I plan to use identify task from the client. My query should i publish my map as MAP service or is there any other service i need to use for accessing identify task from client.
NAdeem
