gsteinmon
NumPyArrayToFeatureClass crashes on "from" field
Discussion created by gsteinmon on Oct 19, 2012
Latest reply on Oct 19, 2012 by csny490
Hey folks,
I was trying to use the da tools and found that "NumPyArrayToFeatureClass" crashed on me when I added a from field. "NumPyArrayToFeatureClass" seems to be putting in a sql request that doesn't work when the "from" field is added because it screws up the sql select statement.
2 things
1) I can not solve this because the function doesn't like field names with quotes embeded and I cannot try to add paranthesis around the field statement.. so oy... it's stuck
2) Is there a way to make sql requests to the file gdb? I thought that was only for sde connections?
Thanks in advance for any suggestions and thoughts.
Guido
Outcomes
