sashi34u
Distance between points in two shapefiles
Discussion created by sashi34u on Oct 18, 2012
Latest reply on Oct 18, 2012 by MBoucher21
I am trying to get the distance between the points in two datasets. For this I have created two point feature shapefiles using the corresponding two datasets. Now, to get the distance between the points, I have used the point distance tool under Analysis Tools>Proximity Analysis. However, for some reason the process is failing is failing. I have defined the coordinate system for the point features as a projected coordinated system (UTM NAD 1983 17N).
The specific error was 999999 which was error in executing the function. Can someone please suggest a solution for this issue.
PS: There is no specific sub forum for Analysis tools. As such, I have posted my query under this section.
Outcomes
