I am new to this and try to figure out how to create a floating window after measurement button is clicked. Thank you. Here is the code: <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd"> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" /> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title> Measure Tool </title> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.2/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.2/js/esri/css/esri.css" /> <link rel="stylesheet" type="text/css" href="https://serverapi.arcgisonline.com/jsapi/arcgis/2.7/js/dojo/dojox/layout/resources/floatingpane.css" /> <style type="text/css"> html,body { height:100%; width:100%; margin:0; } body { background-color:#FFF; overflow:hidden; font-family:"Trebuchet MS"; } #map { border:solid 2px #808775; -moz-border-radius:4px; -webkit-border-radius:4px; border-radius:4px; margin:5px; padding:0px; } #titlePane{ width:240px; } .claro .dijitTitlePaneTitle { background: #808775; font-weight:600; border:solid 1px #29201A; } .claro .dijitTitlePaneTitleHover { background:#808775; } .claro .dijitTitlePaneTitleActive { background:#808775; } .claro .dijitTitlePaneContentOuter { border-right: solid 2px #808775 !important; border-bottom: solid 2px #808775 !important; border-left: solid 2px #808775 !important; } </style> <script type="text/javascript"> djConfig = { parseOnLoad:true }; </script> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.2"></script>
<script type="text/javascript"> dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("dijit.TitlePane"); dojo.require("dijit.form.CheckBox"); dojo.require("esri.map"); dojo.require("esri.dijit.Measurement"); dojo.require("esri.SnappingManager"); dojo.require("esri.dijit.Scalebar"); dojo.require("esri.layers.FeatureLayer"); dojo.require("dojox.layout.FloatingPane"); dojo.require("dijit.form.CheckBox"); var map; function init() {
//This sample may require a proxy page to handle communications with the ArcGIS Server services. You will need to //replace the url below with the location of a proxy on your machine. See the 'Using the proxy page' help topic //for details on setting up a proxy page. esri.config.defaults.io.proxyUrl = "/arcgisserver/apis/javascript/proxy/proxy.ashx"; esri.config.defaults.io.alwaysUseProxy = false; //This service is for development and testing purposes only. We recommend that you create your own geometry service for use within your applications esri.config.defaults.geometryService = new esri.tasks.GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer"); var initialExtent = new esri.geometry.Extent({"xmin":-9545482,"ymin":4615382,"xmax":-9544248,"ymax":4616059,"spatialReference":{"wkid":102100}}); map = new esri.Map("map", { extent:initialExtent });
dojo.connect(map, 'onLoad', function(map) { //resize the map when the browser resizes dojo.connect(dijit.byId('map'), 'resize', map,map.resize); });
var sfs = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([195,176,23]), 2),null); var parcelsLayer = new esri.layers.FeatureLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Louisville/LOJIC_LandRecords_Louisville/M...", { mode: esri.layers.FeatureLayer.MODE_ONDEMAND, outFields: ["*"] }); parcelsLayer.setRenderer(new esri.renderer.SimpleRenderer(sfs)); /* dojo.connect(map, "onLayersAddResult", function(results){ //dojo.keys.copyKey maps to CTRL on windows and Cmd on Mac. var snapManager = map.enableSnapping({snapKey:dojo.keys.copyKey}); var layerInfos = [{layer: parcelsLayer}]; snapManager.setLayerInfos(layerInfos);
var measurement = new esri.dijit.Measurement({ map: map }, dojo.byId('measurementDiv')); measurement.startup();
