Eclipse's Emulator (ArcGIS Android App)?!!
672
6
10-16-2012 04:03 AM
ss3
Hello everyone,
I am new to Eclipse. I am trying to learn it step by step. I am trying to create an ArcGIS app for Android using "Eclipse IDE for Java EE Developers". I followed this tutorial  , and noticed this sentence: "Be sure to have an Android device connected to the machine. We do not support running in an Emulator."
My question is >>> How can I test my app? Is what have been mentioned is true?! I think that this tutorial is old because they are talking about old SDK version.
I thought about using the Eclipse's Emulator, and I tried it, but the app didn't work properly!! I am confused right now; because I don't know whether the problem is that:
                       1) ArcGIS apps don't work on Emulator!
                       2) or My code is wrong!
Thanks.
JMontgomery
Hello everyone,
Thanks.
From what I understand - The emulator is no longer supported. I thought this would have been addressed by now. I agree. the lastthing you really want to do is compile an application and test on a device. Sketchy. Might need to use an older device for testing?
deleted-user-ATjHIWsdQYmT
Occasional Contributor III
With the release of API v. 1.1 Emulators are now supported.  See this blog post:
http://blogs.esri.com/esri/arcgis/2012/05/02/arcgis-runtime-sdk-for-android-v1-1-supports-android-em...
JoeHue
how about API v.2.0 ? Is it still support the emulators?
DanO_Neill
Yes, the emulator is supported with the current v2.0 API.  The documentation will be updated to reflect the fact that you can either setup an emulator or use a physical device.  Thanks for pointing out the error in the documentation.
JoeHue
Thanks. It's a good news for me.
JoeHue
My Laptop has Virtualization Support  but it still doesn't work...
My laptop use AMD E-300 proccessor...
Is there another suggestion to make it work?
