thorn197
HEC-GeoRAS Inudation Mapping - New (File Geodatabase) not working with HEC-RAS import
Discussion created by thorn197 on Oct 15, 2012
Latest reply on Feb 19, 2020 by Romoke
I am working with ArcGIS 9.3.1 and HEC-GeoRAS 4.3.93.  I am having two baffling problems when trying to produce the inundation maps with the data imported to ArcGIS via HEC-RAS 4.2 Beta.
Firstly, if I import the RAS Data to a "New (File Geodatabase)", I can not get past the step "Floodplain Deliniation Using Rasters" of the "Inundation Mapping" section.  I get a series of errors listed below:
"Failed to create mask feature class! System.Runtime.InteropServices.COMException (0x80041292): The spatial index grid size is invalid. at ESRI.ArcGIS.Geodatabase.IFeature.Store() at HECGeoRAS.clsMFloodGRIDIntersection.GetMaskFeatureClass(IFeatureClass pBP, IFeatureClass pSA)"
"System.NullReferenceException: Object reference not set to an instance of an object. at HECGeoRAS.clsMFloodGRIDIntersection.GetCombinedWaterSurface(IGeoDataset pWSDS, IFeatureClass pSA, IFeatureClass pSA, IFeatureClass pBP, IQueryFilter pQF)"
"System.NullReferenceException: Object reference not set to an instance of an object. at HECGeoRAS.clsMFloodGRIDIntersection.CalcDiffGRIDMonolith(IGeoDatasetpWSDS, String sUniqueDepthGRIDName)"
"Failed to complete floodplain mapping successfully!"
Secondly, I have used the "Classic (Personal Geodatabase)" Ras Import method and have had 100% SUCCESS in producing the inundation maps with NO errors.  This took an unfortunate significant amount of time to process for one water surface profile, but I obtained the results that I needed.
The problem is that I need to produce these results for around 20 water surface profiles.  When I tried processing these inundation maps for all 20 water surface profiles (had to let the job run over the whole weekend), I ended up getting another series of errors in the "Floodplain Deliniation Using Rasters" section.  The errors are listed below:
"Failed to convert TIN to GRID.  Attempted to read or write protected memory.  This is often an indication that other memory is corrupt. lineposition= 8"
The wierd part is that results for one water surface profile were produced during this 20 water surface profile execution.
In summary, the Import Ras data as a "New (File Geodatabase)" option is not working when trying to produce inundation maps.  The Import Ras as  a "Classic (Personal Geodatabase)" option is working for producing inundation maps, but only when processing one water surface profile.  This is also taking a significant amount of time to process (hours per a water surface profile).
I have been fighting these problems for several days now... Please help!!!
Much appreciated,
Jonathon Thornburg
Outcomes
