You can do this client side with esri.geometry.getLineIntersection. Here's an example:
<!doctype html>
<html lang="en">
<head>
<meta charset="utf-8">
<meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
<title></title>
<link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.2/js/dojo/dijit/themes/tundra/tundra.css">
<link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.2/js/esri/css/esri.css">
<style>
html, body { height: 100%; width: 100%; margin: 0; padding: 0; }
#map{ margin: 0; padding: 0; }
</style>
<script>var dojoConfig = { parseOnLoad: true };</script>
<script src="http://serverapi.arcgisonline.com/jsapi/arcgis/3.2/"></script>
<script>
dojo.require("dijit.layout.BorderContainer");
dojo.require("dijit.layout.ContentPane");
dojo.require("esri.map");
var map;
function init() {
var bounds = new esri.geometry.Extent({"xmin":-16108713,"ymin":2819886,"xmax":-9494769,"ymax":5549605,"spatialReference":{"wkid":102100}});
map = new esri.Map("map",{ extent: bounds });
var basemap = new esri.layers.ArcGISTiledMapServiceLayer("https://server.arcgisonline.com/ArcGIS/rest/services/Canvas/World_Light_Gray_Base/MapServer");
map.addLayer(basemap);
dojo.connect(map, "onLoad", function() {
dojo.connect(dijit.byId("map"), "resize", map, map.resize);
showLines();
function showLines() {
var geometries = [
[[-120,30],[-110,40]],
[[-120,40],[-110,30]]
dojo.forEach(geometries, function(path) {
var line = new esri.geometry.Polyline(new esri.SpatialReference({ "wkid": 4326 }));
line.addPath(path);
var merc = esri.geometry.geographicToWebMercator(line);
addGraphic(merc);
clientSideIntersection();
function clientSideIntersection() {
var g1 = map.graphics.graphics[0].geometry;
var g2 = map.graphics.graphics[1].geometry;
var s1 = new esri.geometry.Point(g1.paths[0][0], map.spatialReference);
var e1 = new esri.geometry.Point(g1.paths[0][1], map.spatialReference);
var s2 = new esri.geometry.Point(g2.paths[0][0], map.spatialReference);
var e2 = new esri.geometry.Point(g2.paths[0][1], map.spatialReference);
var intersection = esri.geometry.getLineIntersection(s1, e1, s2, e2);
console.log("intersection: ", intersection);
map.graphics.add(new esri.Graphic(intersection, new esri.symbol.SimpleMarkerSymbol()));
function addGraphic(geom) {
var sym = new esri.symbol.SimpleLineSymbol();
map.graphics.add(new esri.Graphic(geom, sym));
dojo.ready(init);
</script>
</head>
<body class="tundra">
<div data-dojo-type="dijit.layout.BorderContainer"
data-dojo-props="design:'headline',gutters:false"
style="width: 100%; height: 100%; margin: 0;">
<div id="map"
data-dojo-type="dijit.layout.ContentPane"
data-dojo-props="region:'center'">
</div>
</div>
</body>
</html>
