floryar
'Select Layer By Location' Not Working Properly
Discussion created by floryar on Oct 11, 2012
Latest reply on Oct 22, 2012 by mzcoyle
(Note 1: I'm using Arc 10.1 and PyScripter)
(Note 2: Thank you, thank you, thank you in advanced for reading the monster explanation below!  I am extremely frustrated and would greatly appreciate any help!)
I'm not sure how to briefly sum-up my issue, but (very generally) I'm trying to assign values to a flag field in a point shapefile, where the flag field designates groups of points, and each group represents a collection of points that can be buffered to a given buffer size of interest without having their buffers overlap.  So basically, I'm sub-setting the point dataset into groups that, when buffered, have buffers that won't overlap.
My logic follows a loop whereby:
1) All non-flagged features are selected,
2) Any features falling within "CombinedBuffers.shp" (see definition below) are removed from the selection,
3) First feature in remaining selection is chosen (i.e., basically random),
4) This feature is flagged (for ex., "1" - for group 1),
5) Then this feature is buffered, and the buffer is added (appended) to a "combined buffers" shapefile (each buffer added to this shapefile represents an area under which additional "group 1" points cannot fall; the shapefile is emptied when a new group starts),
6) The code loops back to the top again - selecting all points not flagged, removing those under buffered areas, selecting the first feature, etc.
7) Once all possible points have been designated as group 1, CombinedBuffers.shp is emptied and the loop starts again on the subset of points not flagged (this time, assigning points to group 2, etc.)
My problem is introduced in #2 above: removing points from the current selection based on location.  (Note: Selection in #1 works fine.)  No error is thrown for selection #2, it simply does not remove any points when it should (proven by record count).
What I've already tried/checked:
1) "Input" and "CombinedBuffers" datasets are shapefiles, but I've also tried them as feature classes in a personal geodatabase.
2) All data are in the same projected coordinate system; all data are stored in the same location.
3) Selection #1 followed by selection #2 works manually in ArcMap with tool interfaces AND the python window (using the same code!).
4) The appended buffer in CombinedBuffers.shp IS being recognized (feature counts are correct after each added buffer).
5) I have changed the type of selection, and it still will not select properly.
6) I have used similar selection sets in previous codes (and they worked), but I have not tested them using 10.1 yet.  Could this be a 10.1 issue?
My code is below (Note: sorry for the lengthiness - anyone willing to read through this is highly commended and your help incredibly appreciated!):
#STEP 1: GENERAL SETTINGS-------------------------------------------------------
# Imports...
import time
print "Start time:",time.ctime()
StartSecs = time.clock()
import Functions
import arcpy
import sys
import traceback
import easygui
from arcpy import env
from arcpy.sa import *
# Variables...
BuffDist = 10
BuffUnit = "Kilometers"
Input = "C:/.../TestWells_TabAreaInput.shp"
Output = "C:/.../TestWells_TabAreaOutput.shp"
CmbdBuffs = "C:/.../CmbdBuffs.shp"
TempBuff = "C:/.../TempBuff.shp"
SpatialRef = arcpy.Describe(Input).spatialReference
Scratch_Path = "C:/.../Scratch"
CursorExists = "No"
RowExists = "No"
# Environments...
env.workspace = Scratch_Path
env.scratchWorkspace = Scratch_Path
env.overwriteOutput = "True"
env.extent = "C:/.../FC_Poly_IAState"
env.mask = "C:/.../FC_Poly_IAState"
env.maintainSpatialIndex = False
# Enable error handling...
try:
# STEP 2: CREATE POINTS FEATURE LAYER AND BUFFER FEATURE CLASS------------------
    # Make 'wells' feature layer and set flag field = 0...
    arcpy.MakeFeatureLayer_management(Input,"InputLyr")
    arcpy.CalculateField_management("InputLyr","BuffSelFlg",0)
    n = int(arcpy.GetCount_management("InputLyr").getOutput(0))
    print "Total (n) Records =", n
    # Create empty buffer feature class...
    Buffer = str(BuffDist*2) + " " + BuffUnit  # For these processes, buffers are defined as 2x buffer size of interest.
    if arcpy.Exists(CmbdBuffs):
        arcpy.Delete_management(CmbdBuffs)
    arcpy.Buffer_analysis("InputLyr",CmbdBuffs,Buffer)
    arcpy.DeleteFeatures_management(CmbdBuffs)
    BufferCnt = int(arcpy.GetCount_management(CmbdBuffs).getOutput(0))
    print "Buffer Count =", BufferCnt
    x = 1  # (assigned group value/flag)
# STEP 3: START LOOP------------------------------------------------------------
# Note: The use of "group" below is defined as a group of wells that can be buffered
# to the buffer size of interest without having their buffers overlap.
    while x <= n:
        # Select wells that have not been added to a group (i.e., where flag = 0)...
        arcpy.SelectLayerByAttribute_management("InputLyr","NEW_SELECTION",'"BuffSelFlg" = 0')
        RcdCnt = int(arcpy.GetCount_management("InputLyr").getOutput(0))
        print "Record Count where flag is zero =", RcdCnt
        if RcdCnt > 0:  # (i.e., if there are wells that have not been added to any group...)
            # Remove (from selection) wells within the current group's buffers...
            arcpy.SelectLayerByLocation_management("InputLyr","INTERSECT",CmbdBuffs,"","REMOVE_FROM_SELECTION")
            OutsideBuffRcdCnt = int(arcpy.GetCount_management("InputLyr").getOutput(0))
            print "Record Count where flag is zero and wells are outside buffers =", RcdCnt
            # NOTE: THIS IS THE SELECTION THAT DOES NOT WORK
            if OutsideBuffRcdCnt > 0:  # (i.e., if there are wells left that are qualified for assignment into this group...)
                UpdtCur = arcpy.UpdateCursor("InputLyr","",SpatialRef)
                row = UpdtCur.next()
                row.BuffSelFlg = x
                UpdtCur.updateRow(row)
                UnqID = row.UnqRecordI
                print "UnqID =",UnqID
                arcpy.SelectLayerByAttribute_management("InputLyr","NEW_SELECTION","\"UnqRecordI\" = '" + UnqID + "'")
                arcpy.Buffer_analysis("InputLyr",TempBuff,Buffer)
                arcpy.Append_management(TempBuff,CmbdBuffs,"NO_TEST")
                arcpy.AddSpatialIndex_management(CmbdBuffs)
                arcpy.SelectLayerByAttribute_management("InputLyr","CLEAR_SELECTION")
                arcpy.Delete_management(TempBuff)
                del UpdtCur
                del row
            else: # (Start a new group)
                x = x + 1
        else: # (All records have been flagged into groups - job done!)
            break
# STEP 4: COPY FEATURES AND DELETE FEATURE LAYER----------------------------
    arcpy.CopyFeatures_management("InputLyr",Output)
    arcpy.Delete_management("InputLyr")
# ERROR HANDLING----------------------------------------------------------------
except arcpy.ExecuteError:
    # Get the tool error messages:
    msgs = arcpy.GetMessages(2)
    # Return tool error messages for use with a script tool:
    arcpy.AddError(msgs)
    # Print tool error messages for use in Python/Python Window:
    print "Geoprocessing tool error:"
    print msgs
except:
    # Get the traceback object:
    tb = sys.exc_info()[2]
    tbinfo = traceback.format_tb(tb)[0]
    # Concatenate info together concerning the error into a message string:
    pymsg = "PYTHON ERRORS:\nTraceback info:\n" + tbinfo + "\nError Info:\n" + str(sys.exc_info()[1])
    msgs = "ArcPy ERRORS:\n" + arcpy.GetMessages(2) + "\n"
    # Return python error messages for use in script tool or Python Window:
    arcpy.AddError(pymsg)
    # Print Python error messages for use in Python/Python Window:
    print arcpy.GetMessages()
    print pymsg
finally:
    if CursorExists == "Yes":
        del InputCur
    if RowExists == "Yes":
        del row
    if arcpy.Exists("InputLyr"):
    print "End time:",time.ctime()
    TimeElapsed, Step = (time.clock()-StartSecs), "END"
    Functions.PrintTime(TimeElapsed,Step)
Outcomes
