rhexter
Imported cga attribute bug
Discussion created by rhexter on Oct 11, 2012
Latest reply on Oct 12, 2012 by MBuehler-esristaff
I have a number of generic attributes that appeared better to be put into a separate cga script then be imported to each cityzone rule that required them.
One of those attributes is used to specify the height of a building.
This specific attribute is linked via a layer attribute to a map layer, the map layer has a texture to describe the heights of the buildings in different areas of the area the rule is applied.
I notice that each time I restart the cityengine
Attribute Connection Editor -> Layer Attribute-> "Select source" is not remembered I have to reset this.
So in summation:
The imported attribute is assigned a specific mapping within the script that it is imported too, but it does not remember the specific assignment value.
Outcomes
