define(["dojo/_base/declare", "esri/layers/FeatureLayer", "esri/layers/agstiled", "esri/layers/dynamic" ], function (declare, FeatureLayer, TiledLayer, DynamicLayer) { return declare([], { id: null, agsid: null, URL: null, layertype: null, maplayer: null, constructor: function (lyr) { this.id = lyr.Layer_ID; this.ags_id = lyr.AGS_ID; this.layertype = lyr.LayerType; switch (this.layertype) { case "featurelayer": this.URL = lyr.Service_URL + "/FeatureServer/" + this.agsid; this.maplayer = new esri.layers.FeatureLayer(this.URL, { mode: esri.layers.FeatureLayer.MODE_ONDEMAND, outFields: ["*"] }); break; case "tiled": this.URL = lyr.Service_URL + "/MapServer" + ((this.agsid) ? ("/" + this.agsid) : ("")); this.maplayer = new TiledLayer(this.URL); break; case "dynamic": this.URL = lyr.Service_URL + "/MapServer" + ((this.agsid) ? ("/" + this.agsid) : ("")); this.maplayer = new DynamicLayer(this.URL); //this.maplayer = new esri.layers.ArcGISDynamicMapServiceLayer(this.URL); break; default: this.URL = lyr.Service_URL + "/MapServer" + ((this.agsid) ? ("/" + this.agsid) : ("")); this.maplayer = new DynamicLayer(this.URL); //this.maplayer = new esri.layers.ArcGISDynamicMapServiceLayer(this.URL); break; } } }); });
Solved! Go to Solution.
define(["dojo/_base/declare", "esri/layers/FeatureLayer", "esri/layers/agstiled", "esri/layers/dynamic"], function (declare, FeatureLayer, TiledLayer, DynamicLayer) { return declare([], { id: null, agsid: null, URL: null, layertype: null, maplayer: null, constructor: function (lyr) { this.id = lyr.Layer_ID; this.ags_id = lyr.AGS_ID; this.layertype = lyr.LayerType; switch (this.layertype) { case "featurelayer": this.URL = lyr.Service_URL + "/FeatureServer/" + this.ags_id; // was previously agsid ... missing underscore this.maplayer = new esri.layers.FeatureLayer(this.URL, { mode: esri.layers.FeatureLayer.MODE_ONDEMAND, outFields: ["*"] }); break; case "tiled": this.URL = lyr.Service_URL + "/MapServer" + ((this.agsid) ? ("/" + this.agsid) : ("")); this.maplayer = new TiledLayer(this.URL); break; case "dynamic": this.URL = lyr.Service_URL + "/MapServer" + ((this.agsid) ? ("/" + this.agsid) : ("")); this.maplayer = new DynamicLayer(this.URL); //this.maplayer = new esri.layers.ArcGISDynamicMapServiceLayer(this.URL); break; default: this.URL = lyr.Service_URL + "/MapServer" + ((this.agsid) ? ("/" + this.agsid) : ("")); this.maplayer = new DynamicLayer(this.URL); //this.maplayer = new esri.layers.ArcGISDynamicMapServiceLayer(this.URL); break; } } }); });
<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" /> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title></title> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.2/js/esri/css/esri.css" /> <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } .esriScalebar{ padding: 20px 20px; } #map{ padding:0; } </style> <script> var dojoConfig = { packages: [{ "name": "extras", "location": location.pathname.replace(/\/[^/]+$/, '') + "" }] }; </script> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/3.2compact"></script> <script type="text/javascript"> var map; require([ "dojo/parser", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "esri/map", "extras/LayerWrapper" ], function(parser, BC, CP, Map, Layer) { // create layout dijits parser.parse(); // create a map map = new esri.Map("map", { "extent": new esri.geometry.Extent({"xmin":-13635599,"ymin":4545388,"xmax":-13632458,"ymax":4546651,"spatialReference":{"wkid":102100}}) }); // add streets var url = "http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"; var tiled = new esri.layers.ArcGISTiledMapServiceLayer(url); map.addLayer(tiled); // add the feautre layer, via the layer wrapper var flInfo = { "Layer_ID": "counties", "AGS_ID": 0, "LayerType": "featurelayer", "Service_URL": "http://sampleserver6.arcgisonline.com/arcgis/rest/services/SF311" }; var fl = new Layer(flInfo); console.log("created fl: ", fl); map.addLayer(fl.maplayer); }); </script> </head> <body> <div dojotype="dijit.layout.BorderContainer" design="headline" gutters="false" style="width: 100%; height: 100%; margin: 0;"> <div id="map" dojotype="dijit.layout.ContentPane" region="center" style="border:1px solid #000;padding:0;"> </div> </div> </body> </html>
