AnsweredAssumed Answered
SetValue help?
Question asked by rgthurau on Oct 4, 2012
Latest reply on Oct 4, 2012 by rgthurau
Hi All,
Trying to run a basic field update, but getting error.
Code:
ClassList=["Tree_Canopy", "Impervious", "Vegetation", "Soil", "Water"]  AcEvalRas=(os.path.join(DirAc, "AcEvalRas_g"+str(i)+"i")) rows = arcpy.UpdateCursor(AcEvalRas) for row in rows:     if row.Value == 1:         row.SetValue(row.Class, ClassList[0])         row.SetValue(row.Ref, ClassList[0])         rows.updateRow(row)     elif row.Value == 2:         row.Class = row.getValue(ClassList[1])         row.Ref = row.getValue(ClassList[1])         rows.updateRow(row)     elif row.Value == 3:         row.Class = row.getValue(ClassList[2])         row.Ref = row.getValue(ClassList[2])         rows.updateRow(row)     elif row.Value == 4:         row.Class = row.getValue(ClassList[3])         row.Ref = row.getValue(ClassList[3])         rows.updateRow(row)
Error Code:
  File "X:\\TV_LC_2.4_Accuracy2_overlay.py", line 66, in <module>
  File "C:\Program Files\ArcGIS\Desktop10.0\arcpy\arcpy\arcobjects\_base.py", line 28, in __getattr__
    raise AttributeError("%s" % attr)
AttributeError: SetValue
Line 66 is the first "SetValue" line.
I have tried several different versions, where I use setValue and getValue. I even tried a setValue(row.Class, row.getValue(ClassList[0])). The first elif line seems the cleanest to me, but that gives a 99999 Failure to Execute error. From the error messages, I think the first SetValue from the code above is the best so far.
Does the syntax look okay? Any ideas would be great.
This is a raster dataset within a GDB. Fields "Class" and "Ref" are both text with default precision.
Rich
Outcomes
