Kate29
Help with Script to Loop through DEMs and get Raster Properties
Discussion created by Kate29 on Oct 4, 2012
Latest reply on Mar 12, 2015 by VRaghunathan-esristaff
#01/10/2012
#Script to automate terrain analysis
#Kate Lyndegaard
import arcpy
import os
import traceback
import sys
import fnmatch
from arcpy.sa import *
# Check out the ArcGIS Spatial Analyst extension license
#DEM
demPath = arcpy.GetParameterAsText(0)
#Output folder
outputFolder = arcpy.GetParameterAsText(2)
#Set workspace
arcpy.env.workspace = arcpy.GetParameterAsText(1)
try:
    # Execute Int
    outDEM = Int(demPath)
    # Save the output
    outDEM.save("outDEM")
    #Split raster
    arcpy.SplitRaster_management(outDEM, outputFolder, "Tile", "SIZE_OF_TILE", "GRID", "BILINEAR", "", "5280 5280","","FEET")
except:
    # Get the traceback object
    tb = sys.exc_info()[2]
    tbinfo = traceback.format_tb(tb)[0]
    # Concatenate information together concerning the error into a message string
    pymsg = "PYTHON ERRORS:\nTraceback info:\n" + tbinfo + "\nError Info:\n" + str(sys.exc_info()[1])
    msgs = "ArcPy ERRORS:\n" + arcpy.GetMessages(2) + "\n"
    # Return python error messages for use in script tool or Python Window
    arcpy.AddError(pymsg)
    arcpy.AddError(msgs)
try:
    #Output folder
    #Set workspace
    arcpy.env.workspace = outputFolder
    demList = arcpy.ListRasters()
    for dem in demList:
        elevSTDresults = arcpy.GetRasterProperties_management(dem,"STD")
        elevSTD = elevSTDresults.getOutput(0)
        elevSTDNUM = float(elevSTD)
        if elevSTDNUM < 66:
            arcpy.Rename_management(dem, "flat_" + dem)
        elif elevSTDNUM > 66 and elevSTDNUM < 328:
            arcpy.Rename_management(dem, "phill_" + dem)
        elif elevSTDNUM > 328:
            arcpy.Rename_management(dem, "hill_" + dem)except:
try:
    #Output folder
    #Set workspace
    demList1 = arcpy.ListRasters()
    for dem in demList1:
        if fnmatch.fnmatch(dem,"flat_*"):
            arcpy.RasterToPolygon_conversion(outputFolder + "\\" + dem, outputFolder+ "\\" + dem +".shp", "SIMPLIFY")
        elif fnmatch.fnmatch(dem,"phill_*"):
        elif fnmatch.fnmatch(dem,"hill_*"):
except:
try:
    #Output folder
    #Set workspace
    #Create folders to hold merged output
    flatFolder = arcpy.CreateFolder_management(outputFolder, "Flat")
    partFolder = arcpy.CreateFolder_management(outputFolder, "Partly_Hilly")
    hillFolder = arcpy.CreateFolder_management(outputFolder, "Hilly")
    flatFile = arcpy.ListFeatureClasses("flat*", "Polygon")
    tempListf = []
    for list in flatFile:
        item = list + ';'
        tempListf.append(item)
        finalListf = ''.join(tempListf)
        mergeStrF = finalListf.rstrip(';')
        mergeStrF2 = outputFolder + "\\" + mergeStrF
    phillFile = arcpy.ListFeatureClasses("phill*", "Polygon")
    tempListp = []
    for list in phillFile:
        item = list + ';'
        tempListp.append(item)
        finalListp = ''.join(tempListp)
        mergeStrP = finalListp.rstrip(';')
        mergeStrP2 = outputFolder + "\\" + mergeStrP
    hillFile = arcpy.ListFeatureClasses("hill*", "Polygon")
    tempListh = []
    for list in hillFile:
        item = list + ';'
        tempListh.append(item)
        finalListh = ''.join(tempListh)
        mergeStrH = finalListh.rstrip(';')
        mergeStrH2 = outputFolder + "\\" + mergeStrH
    # Provide name and path of the merged feature class
    flatMerged = outputFolder + "\\" + "Flat" + "\\" + "flatMerged.shp"
    phillMerged = outputFolder + "\\" + "Partly_Hilly" + "\\" + "phillMerged.shp"
    hillMerged =outputFolder + "\\" + "Hilly" + "\\" + "hillMerged.shp"
    if not tempListf:
        pass
    else:
        arcpy.Merge_management(mergeStrF2, flatMerged)
    if not tempListp:
        pass
    else:
        arcpy.Merge_management(mergeStrP2, phillMerged)
    if not tempListh:
        pass
    else:
        arcpy.Merge_management(mergeStrH2, hillMerged)
except:
After running the above code, I'm getting the error: ExecuteError: ERROR 001100: Failed because no statistics is available.
Failed to execute (GetRasterProperties).
I'm not sure why I'm getting this error as statistics have been calculated for the input DEM. The script seems only to read the first few tiles of the split raster output- then it fails. Does anyone have any suggestions?
Thank you
Outcomes
