AnsweredAssumed Answered
Exposing elevation slope aspect values when publishing Terrain Data
Question asked by wmarcell on Oct 3, 2012
Latest reply on Oct 4, 2012 by wmarcell
I have been wrestling with a problem and am turning to the forums for help.
We have a terrain dataset that was generated from x,y point data.  When I add this layer to a map and publish I cannot turn on WCS as the layer does not support it.
I would like the client to be able to click on the terrain map service with the identify tool and see the corresponding elevation, Slope, and Aspect values that you can see when identifying on the terrain dataset in ArcMap.
So first, is this even possible?  I have tested in version 10.0 and 10.1 and cannot figure anything out.  Second, If it is possible can someone provide guidance or a link to the solution?  I really think that this functionality should be possible using ArcGIS Server, especially with the prevailance of LiDAR/Elevation data and ESRI's push to support it.  If this is not a supported function, will it be added in a future release?
The only partial solution I have found is converting the terrain dataset to a raster.  I placed the raster below the terrain dataset and published which allowed the client to identify the elevation values within the raster.  This does not expose the slope and aspect information though.
Thanks for any assistance!
Outcomes
