nqazi
Geoprocessing buffer service
Discussion created by nqazi on Oct 2, 2012
I have used buffer toolbox from the proximity tool using model builder. the input features  parameter for the buffer is of the type feature set and on the import schema symbology from box i have passed point feature class. now when i run this tool from my arcmap and passed the features from one of the open map layer a new polygon result is created and it also contains data,however when i run the same tool with same input feature layer after publishing it as geoprocessing service the tool is run successfully  the polygon layer is created but there is no data in it,any guess whats the reason.
Outcomes
