Using Tile Packages in Engine
662
10-01-2012 01:36 PM
ManoSadeh
Hey,
Is it possible to open a Tile Package File (*.tpk) with Engine. We have an Engine application and would like to be able to add a Tile Package to the MapControl.
We know Tile Packages are new in 10.1, but still would like to know if this is availble via ArcObjects and a MapControl.
Thanks and regards,
Mano
DavidLednik
Occasional Contributor II
It works in Desktop with 10.1 so it shouldn't be a problem with 10.1 engine.
Regards,
David
JohnHauck
You can make use of IPackageFile.Unpack to unpack the TPK prior to adding its layer:
string unpackPath = "";
IPackageFile pkFile = new PackageFileClass();
pkFile.Unpack(@"C:\temp\tpk\TPK_Map.tpk", ref unpackPath);
axMapControl1.AddLayerFromFile(unpackPath + "\\Layers.lyr");
I like to enable OLEDrop and click/drag them to the map control, here is a trimmed down version of that code:
private void axMapControl1_OnOleDrop(object sender, IMapControlEvents2_OnOleDropEvent e)
    IDataObjectHelper dataObject = (IDataObjectHelper)e.dataObjectHelper;
    if (e.dropAction == esriControlsDropAction.esriDropped)
        if (dataObject.CanGetFiles())
            System.Array filePaths = System.Array.CreateInstance(typeof(string), 0, 0);
            filePaths = (System.Array)dataObject.GetFiles();
            for (int i = 0; i <= filePaths.Length - 1; i++)
                string filePath = filePaths.GetValue(i).ToString();
                if (filePath.Contains(".tpk"))
