AnsweredAssumed Answered
Database permissions to SDE and access to ArcGIS Server advice
Question asked by hsiddique on Sep 20, 2012
Latest reply on Sep 21, 2012 by hsiddique
Hi all,
I have just installed ArcGIS Server 10.1, and am currently making sure everything works as it should, however I am having problems with publishing a map service.
Currently we have 2 users on the database ("Internet" and "Intranet"), which we give access to particluar layers, I am able to connect to these using the relevent .sde file and add the data I need, however when I try to publish the map service, it tells me that it will copy the data locally for AGS to use, which I dont want, even though i have registered the data source in ArcCatalog.
Is there anything else I need to do that I have missed out, to make sure the data does not get copied locally?
Outcomes
