adig22
Need help. Trying to  do a batch process with python (if possible)
Discussion created by adig22 on Sep 19, 2012
Greetings all,
I am trying to take a list of rasters from one workspace and put them in as inputs to a "BatchExtractByMask" process. I also have another list of polygons to clip by (spatially associated with each raster) that I want to put in as the Mask inputs. First off, is this possible at all? If it is, what am I doing wrong. I run the code below and get a "Problem encountered parse input list" on the line where the second masklist variable is declared (ConversionUtils).
import arcpy, sys, traceback, ConversionUtils
try:
    print "Initializing Program"
    #### Define Workspace and extensions
    # Spatial Analyst Extension
    # Grids workspace
    arcpy.env.workspace = "J:\\USM\\WS722\\Members\\GrcicA\\Scan_Mosaic\\Mask_Polys"
    masklist = arcpy.ListFeatureClasses("*", "ALL")
    # The list is split by semi colons
    masklist = ConversionUtils.SplitMultiInputs(masklist)
    # Scans workspace
    arcpy.env.workspace = "J:\\USM\\WS722\\Members\\GrcicA\\Scan_Mosaic\\Scanned_images"
    rasterlist = arcpy.ListRasters("*", "ALL")
    rasterlist = ConversionUtils.SplitMultiInputs(rasterlist)
    # Define Variables
    outpath = "J:\\USM\WS722\\Members\\GrcicA\\Scan_Mosaic\\Final__Clipped_Images"
    # Delete Existing Data
    # Batch Clip
    print "Extracting"
    extractbymask = arcpy.BatchExtractByMask(rasterlist, masklist)
    extractbymask.save(outpath)
    print "Program Complete"
except:
    tb = sys.exc_info()[2]
    tbinfo = traceback.format_tb(tb)[0]
    pymsg = "PYTHON ERRORS:\nTraceback Info:\n" + tbinfo + "\nError Info:\n     " +        str(sys.exc_type) + ": " + str(sys.exc_value) + "\n"
    msgs = "ARCPY ERRORS:\n" + arcpy.GetMessages(2) + "\n"
    arcpy.AddError(msgs)
    arcpy.AddError(pymsg)
    print msgs
    print pymsg
    arcpy.AddMessage(arcpy.GetMessages(1))
    print arcpy.GetMessages(1)
Any help would be much appreciated. I apologize if I posted this wrong, let me know if I can do anything to improve display of this message. Thanks!
-Adi
Outcomes
