alma29
Loop doesn't work when trying to export
Discussion created by alma29 on Sep 13, 2012
Latest reply on Sep 19, 2012 by smartgirl
I'm trying to create a script to export only those parcels with scale = 1040, but the script will only export the 2 first parcels and I have 3 parcels wich scale is 1040 on the .mxd, seems like the loop doesn't work correctly. Also in order to ensure that the script will do something I have to open the .mxd, go to the first parcel and save the file, if I save the .mxd being on the third or fourth page the script won't do anything, and to make it worse when I took a look at the PDF of the second parcel that was exported, I discovered that on the line that says the scale, the PDF had a wrong scale, it had the text "Scale: 1030" and I don't have any parcel with that scale!
Here are the scales of the parcels on the .mxd that I'm trying to export:
Parcel 1 = Escale: 1040
Parcel 2 = Escale: 1040
Parcel 3 = Escale: 1140
Parcel 4 = Escale: 980
Parcel 5 = Escale: 1000
Parcel 6 = Escale: 1350
Parcel 7 = Escale: 1040
My doubts are:
1.- What is wrong on the loop that the script only exports the first 2 parcels and not
the 3 parcels with scale = 1040
2.- Why the second PDF exported has the wrong Scale (1030) on the Scale line
I will be grateful if someone can help me to figure out what I'm doing wrong
Here is the script:
import arcpy, string
mxd = arcpy.mapping.MapDocument(r"D:\00salida\Plantilla_8x11.mxd")
pageNum = 1
ddp = mxd.dataDrivenPages
df = arcpy.mapping.ListDataFrames(mxd)[0]
for pageNum in range(1, mxd.dataDrivenPages.pageCount + 1):
    if df.scale == 1040:
       print "\nCurrent Value of df.scale " + (str(df.scale))
       mxd.dataDrivenPages.currentPageID = pageNum
       print "EXPORTING " + (str(ddp.pageRow.CVEGEO))
       print "Again Current Value of df.scale: "
       print df.scale
       arcpy.mapping.ExportToPDF(mxd, r"\00salida\PDFS\M" + str(ddp.pageRow.CVEGEO) + ".PDF")
del pageNum, mxd
Here is what I get on the screen as output:
Current Value of df.scale 1040.0
EXPORTING 1102700010125024
1040.0
EXPORTING 1102700010125015
1030.0
Outcomes
