Print Dijit Template Question
763
9
09-12-2012 07:57 AM
by Anonymous User
Not applicable
Attempting to specify which layers are to be included in the legend using the Print Dijit Template sample. However the following line of code essentially bombs the app.
var legendLayer = new esri.tasks.LegendLayer();
Any ideas?
Thanks!
RGibson
JohnGravois
heres a working jsfiddle (just update reference to use your own proxy)
var poolFeatureLayer = new esri.layers.FeatureLayer(permitUrl, {           "mode": esri.layers.FeatureLayer.MODE_SNAPSHOT,               //make sure the layer you wish to add to the legend includes an id to pass to legendLayers           "id": "PoolPermits"         });  // create a print template for each choice         templates = dojo.map(templateNames, function(ch) {           var plate = new esri.tasks.PrintTemplate();    var legendLayer = new esri.tasks.LegendLayer();    //set the layerId property for legendLayer           legendLayer.layerId = "PoolPermits";     //legendLayer.subLayerIds = [];         plate.layout = plate.label = ch;           plate.format = "PDF";           plate.layoutOptions = {              "authorText": "May by:  Esri's JS API Team",             "copyrightText": "<copyright info here>",             "titleText": "Pool Permits",              "scalebarUnit": "Miles",                          //this property needs to be set with an array of legendLayer objects, not layerIds      "legendLayers": [legendLayer],            };           return plate;         });
JohnGravois
try setting a layerId (and optionally subLayerIds) for legendLayers before the object is passed in the layoutOptions
http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi/printtemplate.htm#layoutOptions
var myLegendLayer = new esri.tasks.LegendLayer();
myLegendLayer.layerId = "Boundaries";
myLegendLayer.subLayerIds = [];
app.printer = new esri.dijit.Print({
          map: app.map,
    templates: [{
    label: "Layout",
    format: "JPG",
    layout: "Letter ANSI A Landscape",
    preserveScale: false,
    layoutOptions: {
      titleText: "My Print",
      authorText: "esri",
      copyrightText: "My Company",
      scalebarUnit: "Miles",
                                  legendLayer: myLegendLayer
          url: "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export%20Web%20Map%20Task"
        }, dojo.byId("printButton"));
by Anonymous User
Not applicable
Thanks, John, for the quick reply. However I can't get to that point.
Just this line of code by itself.....var legendLayer = new esri.tasks.LegendLayer();.....bombs the app.
Thanks!
RGibson
JohnGravois
where are you placing that line?
can you post a sample application?
by Anonymous User
Not applicable
Let me re-phrase. It doesn't bomb the entire app but rather the "handlePrintInfo" function.
Problem code is in bold italic
Thanks!
RGibson
function handlePrintInfo(resp) {
        var layoutTemplate, templateNames, mapOnlyIndex, templates;
        layoutTemplate = dojo.filter(resp.parameters, function(param, idx) {
          return param.name === "Layout_Template";
        if ( layoutTemplate.length == 0 ) {
          console.log("print service parameters name for templates must be \"Layout_Template\"");
          return;
        templateNames = layoutTemplate[0].choiceList;
        // remove the MAP_ONLY template then add it to the end of the list of templates
        mapOnlyIndex = dojo.indexOf(templateNames, "MAP_ONLY");
        if ( mapOnlyIndex > -1 ) {
          var mapOnly = templateNames.splice(mapOnlyIndex, mapOnlyIndex + 1)[0];
          templateNames.push(mapOnly);
            "authorText": "City of Fort Smith GIS",
            "copyrightText": "Copyright 2012, Fort Smith GIS",
            "legendLayers": [0,1,2,3],
            "titleText": "Chaffee Crossing",
            "scalebarUnit": "Feet"
          return plate;
JohnGravois
by Anonymous User
Not applicable
Once again, thanks John.
However that line of code mentioned above var legendLayer = new esri.tasks.LegendLayer(); isn't agreeable anywhere in my application for some reason. The error is "called_non_callable".
If I place that line of code, and only that single line of code, into the otherwise working sample, it bombs.
RGibson
by Anonymous User
Not applicable
Ugh....figured it out, John.
I had forgotten to include. Still trying to use the 2.7.
<script src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.1"></script>
Thanks for your help..
RGibson
JohnGravois
if you can post a sample app, i would be happy to take a look.
JohnGravois
missed your last post.  glad to hear it. 🙂
