ScottChang25
ArcGIS10.0:Writing geometries in Python Window- Points with ID,X,Y & IDLE Loading
Discussion created by ScottChang25 on Sep 11, 2012
Latest reply on Sep 19, 2012 by ScottChang25
Hi all,
From the Help of ArcGIS 10.0, I have learned the creating of Polylines, Polygons and Multipoints from 2 sets of Points in the Python Window of my ArcGIS 10.0. From the IDLE (Python GUI) of Python 2.5, I can edit the ArcPy-Python scripts and load the corrected, desired scripts to the Python Window for execution to obtain the .shp file and the .mxd Map.
Now I tried to do the "Writing geometries" presented and provided in the Help of ArcGIS 10.0. I have 2 difficulties in storing/using the Point data in the .txt  file and loading/executing the ArcPy-Python script in the Python Window of my ArcGIS 10.0.
The following is copied from the Help of ArcGIS 10.0:
Writing geometries
ArcGIS 10
Using insert and update cursors, scripts can create new features in a feature class or update existing ones. A script can define a feature by creating a point object, populating its properties, and placing it in an array. That array can then be used to set a feature's geometry. A single geometry part is defined by an array of points, so a multipart feature can be created from multiple arrays of points.
Below is an example of a file to be processed by the script that follows. It contains a point ID and an x- and y-coordinate.
1;-61845879.0968;45047635.4861
1;-3976119.96791;46073695.0451
1;1154177.8272;-25134838.3511
1;-62051091.0086;-26160897.9101
2;17365918.8598;44431999.7507
2;39939229.1582;45252847.3979
2;41170500.6291;27194199.1591
2;17981554.5952;27809834.8945
3;15519011.6535;11598093.8619
3;52046731.9547;13034577.2446
3;52867579.6019;-16105514.2317
3;17160706.948;-16515938.0553
The following example shows how to read a text file containing a series of linear coordinates (as above) and use them to create a new feature class.
# Create a new line feature class using a text file of coordinates.
#   Each coordinate entry is semicolon delimited in the format of ID;X;Y
# Import ArcPy and other required modules
import arcpy
from arcpy import env
import fileinput
import string
import os
env.overwriteOutput = True
# Get the coordinate ASCII file
infile = arcpy.GetParameterAsText(0)
# Get the output feature class
fcname = arcpy.GetParameterAsText(1)
# Get the template feature class
template = arcpy.GetParameterAsText(2)
try:
   # Create the output feature class
   arcpy.CreateFeatureclass_management(os.path.dirname(fcname),
                                       os.path.basename(fcname),
                                       "Polyline", template)
   # Open an insert cursor for the new feature class
   cur = arcpy.InsertCursor(fcname)
   # Create an array and point object needed to create features
   lineArray = arcpy.Array()
   pnt = arcpy.Point()
   # Initialize a variable for keeping track of a feature's ID.
   ID = -1
   for line in fileinput.input(infile): # Open the input file
      # set the point's ID, X and Y properties
      pnt.ID, pnt.X, pnt.Y = string.split(line,";")
      print pnt.ID, pnt.X, pnt.Y
      if ID == -1:
         ID = pnt.ID
      # Add the point to the feature's array of points
      #   If the ID has changed, create a new feature
      if ID != pnt.ID:
         # Create a new row or feature, in the feature class
         feat = cur.newRow()
         # Set the geometry of the new feature to the array of points
         feat.shape = lineArray
         # Insert the feature
         cur.insertRow(feat)
         lineArray.removeAll()
      lineArray.add(pnt)
      ID = pnt.ID
   # Add the last feature
   feat = cur.newRow()
   cur.insertRow(feat)
   fileinput.close()
   del cur
except Exception as e:
   print e.message
An array of points is not necessary when writing point features. A single point object is used to set the geometry of a point feature.
All geometries are validated before they are written to a feature class. Issues such as incorrect ring orientation and self-intersecting polygons, among others, are corrected when the geometry is simplified before its insertion.
Problem #1: Where should I shave the data of ID, X-coordinate, and Y-coordinate of the points? I tried to save the point data in the .txt file of my Notepad:
ID,X,Y,
:Is this file right to use in the project?
Problem #2:
I tried to use the IDLE (Python GUI) to load the script of "Writing geometries" to the Python Window of my ArcGIS 10.0 - see the following:
... >>> # Create a new line feature class using a text file of coordinates.
... #   Each coordinate entry is semicolon delimited in the format of ID;X;Y
... # Import ArcPy and other required modules
... import arcpy
... from arcpy import env
... import fileinput
... import string
... import os
... env.overwriteOutput = True
... # Get the coordinate ASCII file
... infile = arcpy.GetParameterAsText(0)
... # Get the output feature class
... fcname = arcpy.GetParameterAsText(1)
... # Get the template feature class
... template = arcpy.GetParameterAsText(2)
... try:
...    # Create the output feature class
...    arcpy.CreateFeatureclass_management(os.path.dirname(fcname),
...                                        os.path.basename(fcname),
...                                        "Polyline", template)
...    # Open an insert cursor for the new feature class
I am lost now.  Please kindly help and enlighten me in handling the above-mentioned 2 problems.
Thanks in advance,
Scott Chang
Outcomes
