AnsweredAssumed Answered
MouseOver and Click Not working together
Question asked by prashantpal on Sep 6, 2012
Latest reply on Sep 7, 2012 by geos_rfleet
Hi All,
I am trying to provide Info-tips at HoverOver and OnClick for a layer. Separately running these two works
totally fine. Its just when I try to combine these two, only the HoverOver works. Please let me know what
can I change in the code.
Below is the Code for working OnClick InfoWindow
function hoverfunction(map) {
        //build query task
        var queryTask = new esri.tasks.QueryTask("http://usf-960-1-win7/arcgis/rest/services/layer_use/MapServer/0");
        //build query filter
        var query = new esri.tasks.Query();
        query.returnGeometry = true;
        query.where="OBJECTID > 1";
        query.outFields = ["Building_Name","Building_No"];
        query.outSpatialReference = {"wkid":102100};
        var infoTemplate = new esri.InfoTemplate();
        infoTemplate.setTitle("${Building_Name}");
        infoTemplate.setContent( "<b>Building Number </b>${Building_No}<br/>");
        map.infoWindow.resize(245,125);
        dojo.connect(queryTask, "onComplete", function(featureSet) {
        map.graphics.clear();
          var symbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol          (esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255,255,255,0.8]), 1),new dojo.Color([125,125,125,0.65]));
          //QueryTask returns a featureSet.  Loop through features in the featureSet and add them to the map.
            dojo.forEach(featureSet.features,function(feature){
            var graphic = feature;
            graphic.setSymbol(symbol);
            graphic.setInfoTemplate(infoTemplate);
            map.graphics.add(graphic);
        queryTask.execute(query);
Now Here the code where I try to Combine Hover and Onclick.
        //build query task
        var i;
          var symbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255,255,255,0.8]), 1),new dojo.Color([125,125,125,0.65]));
          var highlightSymbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255,0,0]), 3), new dojo.Color([125,125,125,0.35]));
          var buildingHatchesGraphicsLayer = new esri.layers.GraphicsLayer();
          buildingHatchesGraphicsLayer.add(graphic);
          //------------ Add the hoverover -------------
          for (i=0, il=featureSet.features.length; i<il; i++) {
            //Get the current feature from the featureSet.
            //Feature is a graphic
            var graphic = featureSet.features[i];
            //Add graphic to the counties graphics layer.
          map.addLayer(buildingHatchesGraphicsLayer);
          map.graphics.enableMouseEvents();
          map.infoWindow.resize(145,75);
          //listen for when the onMouseOver event fires on the countiesGraphicsLayer
          //when fired, create a new graphic with the geometry from the event.graphic and add it to the maps graphics layer
          dojo.connect(buildingHatchesGraphicsLayer, "onMouseOver", function(evt) {
            //map.graphics.clear();  //use the maps graphics layer as the highlight layer
            var content = evt.graphic.getContent();
            map.infoWindow.setContent(content);
            var title = evt.graphic.getTitle();
            map.infoWindow.setTitle(title);
            var highlightGraphic = new esri.Graphic(evt.graphic.geometry,highlightSymbol);
            map.graphics.add(highlightGraphic);
            map.infoWindow.show(evt.screenPoint,map.getInfoWindowAnchor(evt.screenPoint));
          //listen for when map.graphics onMouseOut event is fired and then clear the highlight graphic
          //and hide the info window
          dojo.connect(map.graphics, "onMouseOut", function(evt) {
            map.infoWindow.hide();
         //-----------------Add Hover Over Ends here ------------------
Please help me out with this problem. I have been stuck here for last two days.
Thanks in Advance
Pal
Outcomes
