Solved! Go to Solution.
<Grid> <esri:Map x:Name="_map" UseAcceleratedDisplay="True" > <!-- ArcGIS Online Tiled Basemap Layer --> <esri:ArcGISTiledMapServiceLayer ID="World Topo Map" Url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"/> <!--Local Feature Layer--> <esri:ArcGISLocalFeatureLayer ID="arcGISLocalFeatureLayer" Path="M:\ArcGIS\Databases\SOPFIM_Full.mpk" UpdateCompleted="ArcGISLocalFeatureLayer_UpdateCompleted" LayerName="ContourQC"> </esri:ArcGISLocalFeatureLayer> </esri:Map> <StackPanel> <TextBlock x:Name="txtBlock" VerticalAlignment="Top" HorizontalAlignment="Left"></TextBlock> <TextBlock x:Name="countBlock" VerticalAlignment="Top" HorizontalAlignment="Left"></TextBlock> </StackPanel> </Grid>
public MainWindow() { var localFeatureService = new LocalFeatureService() { MaxRecords = 10000, Path = @"M:\ArcGIS\Databases\SOPFIM_Full.mpk", }; localFeatureService.Start(); InitializeComponent(); } private void ArcGISLocalFeatureLayer_UpdateCompleted(object sender, System.EventArgs e) { var layer = (sender as ArcGISLocalFeatureLayer); this.txtBlock.Text = layer.ExceededTransferLimit.ToString(); this.countBlock.Text = layer.Graphics.Count.ToString(); }
... <Grid.Resources> <esri:LocalFeatureService x:Key="FeatureService" Path="C:\Temp\SOPFIM_Full.mpk" MaxRecords="1000000" /> </Grid.Resources> ... <esri:ArcGISLocalFeatureLayer ID="arcGISLocalFeatureLayer" Service="{StaticResource FeatureService}" LayerName="ContourQC" IsHitTestVisible="False"/>
<Window.Resources> <esri:LocalFeatureService x:Key="FeatureService" Path="Data\\SOPFIM_Full.mpk" MaxRecords="3000" EnableDynamicLayers="True"/> <esri:SimpleRenderer x:Key="MySimpleRenderer"> <esri:SimpleRenderer.Symbol> <esri:SimpleFillSymbol BorderBrush="Blue" BorderThickness="4" Fill="Red"/> </esri:SimpleRenderer.Symbol> </esri:SimpleRenderer> </Window.Resources> <Grid> <esri:Map x:Name="_map" UseAcceleratedDisplay="True" IsEnabled="false" > <!-- ArcGIS Online Tiled Basemap Layer --> <esri:ArcGISTiledMapServiceLayer ID="World Topo Map" Url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"/> <esri:ArcGISLocalDynamicMapServiceLayer Service="{StaticResource FeatureService}"> </esri:ArcGISLocalDynamicMapServiceLayer> <esri:GraphicsLayer ID="Results" Renderer="{StaticResource MySimpleRenderer}"></esri:GraphicsLayer> </esri:Map> </Grid>
public partial class MainWindow : Window { private const string PATH = "Data\\SOPFIM_Full.mpk"; private LocalMapService _mapService; public MainWindow() { InitializeComponent(); LocalMapService.GetServiceAsync(PATH, localMapService => { _mapService = localMapService; _map.IsEnabled = true; }); this._map.MouseClick += (s, e) => { var graphicsLayer = _map.Layers["Results"] as GraphicsLayer; graphicsLayer.ClearGraphics(); var task = new IdentifyTask(_mapService.UrlMapService); var identifyParameters = new IdentifyParameters() { Geometry = e.MapPoint, SpatialReference = _map.SpatialReference, MapExtent = _map.Extent, Width = (int)_map.ActualWidth, Height = (int)_map.ActualHeight, LayerOption = LayerOption.all }; task.ExecuteCompleted += (se, ea) => { if (ea.IdentifyResults != null && ea.IdentifyResults.Count > 0) { var layer = _map.Layers["Results"] as GraphicsLayer; ea.IdentifyResults.ForEach(x => layer.Graphics.Add(x.Feature)); } }; task.Failed += (se, ea) => MessageBox.Show(ea.Error.ToString()); task.ExecuteAsync(identifyParameters); }; }
