unfortunately the site is all intranet behind firewalls, the code is more than that, but even when i strip it back to the above i still get 2 buttons
dojo.provide("dcc.tool.basemap");
dojo.declare("dcc.tool.basemap", [dijit._Widget], {
parentcontainer: "",
load: function (node, map, file)
this.parentcontainer = node;
this.map = map;
this.file= file;
if (typeof this.contentPane == 'undefined')
this.contentPane = new dijit.form.Button(
label: ' Base Map '
listnerArray.push(dojo.connect(this.contentPane.domNode, "onclick", function ()
curbmPopup.containernode.OpenPopup();
height = (((curbmPopup.containernode.countmaps / 3) ) * 75) + 10;
dojo.byId("bsmapnode").style.height = height + "px";
dojo.byId("bsmapnode").innerHTML = curbmPopup.containernode.BMHtml;
// set highlighted base map
try
dojo.query('#bm_' + curbmPopup.containernode.map.basemap.id)[0].style.border = "2px solid gray"
catch (e)
dojo.place(this.contentPane.domNode, node, "first");
dojo.addClass(this.contentPane.domNode, "claro");
if (typeof this.dropDown == 'undefined')
this.dropDown = new dijit.TooltipDialog(
onClose: function(){ curLoadedPopup.isOpen = false;},
content: '<span style="float:right;position :relative; cursor:pointer;" onclick="dijit.popup.close(curbmPopup);"><img src="' + 'image.gif" alt="X" title="Click to close"/></span><br/><center id="bsmapnode"></center>' ,
style: "width:215px;"
dojo.addClass(this.dropDown.domNode, "claro");
this.dropDown.startup();
this.dropDown.containernode = this;
curbmPopup = this.dropDown;
curLoadedPopup = this.dropDown;
// load basemaps
this.loadBaseMaps(environmentPath + "dcc_GIS_Config/App_Config/basemaps/"+ this.file, this);
OpenPopup: function ()
if (curLoadedPopup.isOpen){
dijit.popup.close(curLoadedPopup);
else
if (typeof curLoadedPopup != 'undefined')
this.popup = dijit.popup.open(
popup: this.dropDown,
around: this.contentPane.domNode,
orient: {
BL: 'TL'
curLoadedPopup.isOpen= true;
loadBaseMaps: function (jsonpath, node)
dojo.xhrGet(
url: jsonpath,
load: function (response)
node.BMHtml = "";
node.countmaps = 0;
dojo.forEach(response.basemaps, function (entry, index, array)
node.BMHtml += '<div id="bm_' + entry.id + '" style=" border:2px solid white; font-size:10px;width :54px;padding:3px; position:relative; float:left; cursor:pointer;" onclick="curbmPopup.containernode.setBaseMap(\'' + entry.URL + '\', \'' + entry.id + '\' , \'' + entry.name + '\' , \'' + entry.type + '\' , \'' + entry.copyright + '\', curbmPopup.containernode.map) ;"> <img width=55 src="' + entry.swatchURL + '"/><center>' + entry.name + '</center></div>';
node.countmaps++;
try
catch (e)
response = null;
return response;
error: function (response, ioArgs)
response = null;
return response;
handleAs: "json"
//this.basemapConfig = this.map.dcc.getJson(jsonpath);
//return this.basemapConfig;
setBaseMap: function (url, id, name, type, copyright, themap)
if (typeof themap.basemap == 'undefined')
this.basemapName = themap._layers[themap.layerIds[0]].id;
themap.basemap = themap._layers[themap.layerIds[0]];
if (this.basemapName != name) //if map has changed
this.basemapId = id;
this.basemapName = name;
this.basemapType = type;
this.url = url;
this.copyright = copyright;
// clear highlighted services
try
dojo.query('#bm_' + curbmPopup.containernode.map.basemap.id)[0].style.border = "2px solid white"
catch (e)
try
themap.removeLayer(themap.basemap);
catch (e)
if (this.basemapType == "ArcGISDynamicMapServiceLayer")
themap.basemap = new esri.layers.ArcGISDynamicMapServiceLayer(this.url, {
transparent: true,
else if (this.basemapType == "ArcGISTiledMapServiceLayer")
themap.basemap = new esri.layers.ArcGISTiledMapServiceLayer(this.url, {
themap.basemap = themap.addLayer(themap.basemap, 0);
myLayers[0].Layer= themap.basemap;
myLayers[0].Label = id;
themap.basemap.url = url;
themap.basemap.id = id;
// themap.dcc.layers.basemap.id = id;
dojo.byId("Copyright").innerHTML = this.copyright;
//highlight mapservice
try
catch (e)
