dojo dialog scroll bar issues
1654
09-03-2012 01:21 PM
AdrianMarsden
Occasional Contributor III
Hi
I have some code that uses an identify task.  In the idenfify task execute function, I loop through the layers found and the fields found to build up a set of tables (one per layer) containing all the field aliases and values - basically recreating the ArcIMS html viewer Identify All results.
I pop these up in a dojo dialog box. The box is defined by CSS as a specific percentage -
.dijitDialog{
  max-height: 50%;
  max-width:50%;
  overflow: auto;
this works fine for a few results, but when I have a fair few results, the vertical scroll bar appears - but the initial position is half way down the document.  I'm not sure if this is something I've missed or an issue with dojo itself.
Cheers
ACM
AdrianMarsden
Resolved adding "autofocus:false" to the creation code works.
