It doesn't look like the locator you are using supports single line address input. You can test this using the rest services directory:http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Locators/ESRI_Geocode_USA/GeocodeServer/f...Here's a modified version of your code using another locator that does support Single Line address input.
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
<head>
<meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />
<!--The viewport meta tag is used to improve the presentation and behavior of the samples
on iOS devices-->
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
<title>Topographic Map</title>
<link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.1/js/dojo/dijit/themes/claro/claro.css">
<style>
html, body { height: 100%; width: 100%; margin: 0; padding: 0; }
.esriScalebar{
padding: 20px 20px;
#map{
padding:0;
</style>
<script type="text/javascript">var djConfig = {parseOnLoad: true};</script>
<script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.1"></script>
dojo.require("dijit.layout.BorderContainer");
dojo.require("dijit.layout.ContentPane");
dojo.require("esri.map");
var locator;
var map;
function init() {
locator = new esri.tasks.Locator("http://tasks.arcgis.com/ArcGIS/rest/services/WorldLocator/GeocodeServer");
dojo.connect(locator, "onAddressToLocationsComplete", showResults);
var initExtent = new esri.geometry.Extent({"xmin":-122.46,"ymin":37.73,"xmax":-122.36,"ymax":37.77,"spatialReference":{"wkid":4326}});
map = new esri.Map("map",{
extent:esri.geometry.geographicToWebMercator(initExtent)
//Add the topographic layer to the map. View the ArcGIS Online site for services http://arcgisonline/home/search.html?t=content&f=typekeywords:service
var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer");
map.addLayer(basemap);
dojo.connect(map, 'onLoad', function(theMap) {
//resize the map when the browser resizes
dojo.connect(dijit.byId('map'), 'resize', map,map.resize);
function locate() {
map.graphics.clear();
var address = {"SingleLine":'380 New York St, Redlands, CA, 92373'};
console.log(address);
locator.outSpatialReference= map.spatialReference;
var options = {
address:address,
outFields:["Loc_name"]
locator.addressToLocations(options);
function showResults(candidates) {
var candidate;
var symbol = new esri.symbol.SimpleMarkerSymbol();
var infoTemplate = new esri.InfoTemplate("Location", "Address: ${address}<br />Score: ${score}<br />Source locator: ${locatorName}");
symbol.setStyle(esri.symbol.SimpleMarkerSymbol.STYLE_SQUARE);
symbol.setColor(new dojo.Color([153,0,51,0.75]));
var geom;
dojo.every(candidates,function(candidate){
console.log(candidate.score);
if (candidate.score > 80) {
console.log(candidate.location);
var attributes = { address: candidate.address, score:candidate.score, locatorName:candidate.attributes.Loc_name };
geom = candidate.location;
var graphic = new esri.Graphic(geom, symbol, attributes, infoTemplate);
//add a graphic to the map at the geocoded location
map.graphics.add(graphic);
//add a text symbol to the map listing the location of the matched address.
var displayText = candidate.address;
var font = new esri.symbol.Font("16pt",esri.symbol.Font.STYLE_NORMAL, esri.symbol.Font.VARIANT_NORMAL,esri.symbol.Font.WEIGHT_BOLD,"Helvetica");
var textSymbol = new esri.symbol.TextSymbol(displayText,font,new dojo.Color("#666633"));
textSymbol.setOffset(0,8);
map.graphics.add(new esri.Graphic(geom, textSymbol));
return false; //break out of loop after one candidate with score greater than 80 is found.
if(geom !== undefined){
map.centerAndZoom(geom,12);
dojo.addOnLoad(init);
</script>
</head>
<body class="claro">
<div dojotype="dijit.layout.BorderContainer" design="headline" gutters="false" style="width: 100%; height: 100%; margin: 0;">
<div dojotype='dijit.layout.ContentPane' region='top' style='height:40px;'>
<button dojotype="dijit.form.Button" onclick="locate()"> Locate</button>
</div>
<div id="map" dojotype="dijit.layout.ContentPane" region="center" style="border:1px solid #000;padding:0;">
</div>
</div>
</body>
</html>
