multicolored graphics/sketch layer
1005
7
08-31-2012 07:06 AM
HamzaHaroon
I'm trying to add different colored graphics to my graphics layer. I have made a graphics renderer and set the AGSSimpleFillSymbol.
When i change the color of the fill symbol, the graphics layer redraws the previous graphics with the new color. How do i make the graphics layer hold graphics of different colors?
NimeshJarecha
You should assign symbol to each graphic rather than assigning a renderer to the graphics layer.
Regards,
Nimesh
HamzaHaroon
this is how i'm adding graphics to my graphics layer
AGSGeometry* sketchGeometry = [[self.sketchLayer.geometry copy] autorelease];
AGSGraphic* graphic = [AGSGraphic graphicWithGeometru: sketchGeometry symbol: lineColor attributes: nil infoTemplateDelegate: nil];
[self.graphicsLayer addGraphic:graphic];
my lineColor is an AGSFillSymbol and assigned in the viewDidLoad method.
AGSCompositeSymbol *mainSym = self.gpsSketchLayer.mainSymbol;
        for (AGSSymbol *s in mainSym.symbols) {
            if ([s isKindOfClass:[AGSSimpleFillSymbol class]])
                lineColor = (AGSSimpleFillSymbol *)s;
                lineColor.outline.color = [UIColor blueColor];
I change my lineColor from buttons.
NimeshJarecha
Did you remove renderer from graphics layer?
Regards,
Nimesh
HamzaHaroon
yea. still changes all of my graphics to the same color.
NimeshJarecha
Are you setting different color for the symbol each time before assigning it to the graphic?
Post a sample application so I can have a look.
Regards,
Nimesh
HamzaHaroon
heres my code in my viewController class. implementing the graphics layer here.
#import "GMViewController.h"
@interface GMViewController ()
@end
@implementation GMViewController
@synthesize painting;
@synthesize colorPalette;
@synthesize colorPicker;
@synthesize mapView = _mapView;
@synthesize tiledLayer;
@synthesize dynamicLayer;
@synthesize sketchLayer;
@synthesize graphicsLayer;
@synthesize midSymbol;
@synthesize vertSymbol;
@synthesize cred;
@synthesize toolbar = _toolbar;
@synthesize sketchToolbar = _sketchToolbar;
@synthesize lineColor;
@synthesize gLine;
- (void)viewDidLoad
    [super viewDidLoad];
    painting1 = [[PaintingView alloc] init];
    [painting1 setDelegate:self];
    [painting setDelegate:self];
    NSString *backgroundLayer = kTiledMapServiceURL1;
    tiledLayer = [[AGSTiledMapServiceLayer alloc] initWithURL:[NSURL URLWithString:backgroundLayer]];
    [self.mapView addMapLayer:tiledLayer withName:@"Tiled Layer"];
    NSString *pass = @"mobile1!";
    cred = [[AGSCredential alloc] initWithUser:@"mobile" password:pass];
    dynamicLayer = [[AGSDynamicMapServiceLayer alloc] initWithURL:[NSURL URLWithString: kDynamicMapServiceURL] credential:cred];
    [self.mapView addMapLayer:dynamicLayer withName:@"Dynamic Layer"];
    //Graphics layer to hold all sketches (points, polylines, and polygons)
  graphicsLayer = [AGSGraphicsLayer graphicsLayer];
 [self.mapView addMapLayer:graphicsLayer withName:@"Graphics Layer"];
    AGSGraphicsLayer *graphicsLayer2 = [AGSGraphicsLayer graphicsLayer];
    [self.mapView addMapLayer:graphicsLayer2 withName:@"Graphics Layer 2"];
 //A composite symbol for the graphics layer's renderer to symbolize the sketches
 AGSCompositeSymbol* composite = [AGSCompositeSymbol compositeSymbol];
 AGSSimpleMarkerSymbol* markerSymbol = [[[AGSSimpleMarkerSymbol alloc] init] autorelease];
 //markerSymbol.style = AGSSimpleMarkerSymbolStyleSquare;
 //markerSymbol.color = [UIColor greenColor];
 //[composite.symbols addObject:markerSymbol];
 AGSSimpleLineSymbol* lineSymbol = [[[AGSSimpleLineSymbol alloc] init] autorelease];
 lineSymbol.color= [UIColor redColor];
 lineSymbol.width = 4;
 [composite.symbols addObject:lineSymbol];
 AGSSimpleFillSymbol* fillSymbol = [[[AGSSimpleFillSymbol alloc] init] autorelease];
 fillSymbol.outline.color = [UIColor redColor];//colorWithRed:1.0 green:0 blue:0 alpha:4] ;
    fillSymbol.outline.width = 4;
 [composite.symbols addObject:fillSymbol];
 AGSSimpleRenderer* renderer = [AGSSimpleRenderer simpleRendererWithSymbol:composite];
 //graphicsLayer.renderer = renderer;
    graphicsLayer2.renderer = renderer;
 //Sketch layer
 sketchLayer = [[[AGSSketchGraphicsLayer alloc] initWithGeometry:nil] autorelease];
 [self.mapView addMapLayer:sketchLayer withName:@"Sketch layer"];
    AGSSketchGraphicsLayer *sketchLayer2 = [[[AGSSketchGraphicsLayer alloc] initWithGeometry:nil]autorelease];
    [self.mapView addMapLayer:sketchLayer2 withName:@"Sketch layer2"];
 //Helper class to manage the UI toolbar, Sketch Layer, and Graphics Layer
 //Basically, where the magic happens
 self.sketchToolbar = [[[GMSketchToolBar alloc] initWithToolbar:self.toolbar
                                                     sketchLayer:sketchLayer2
                                                         mapView:self.mapView
                                                   graphicsLayer:graphicsLayer2] autorelease];
    poly = [[AGSMutablePolyline alloc] initWithSpatialReference:self.mapView.spatialReference];
    midSymbol = self.sketchLayer.midVertexSymbol;
    vertSymbol = self.sketchLayer.vertexSymbol;
    self.sketchLayer.midVertexSymbol = nil;
    self.sketchLayer.vertexSymbol = nil;
    AGSSpatialReference *sr = [AGSSpatialReference spatialReferenceWithWKID:1984];
    AGSEnvelope *env = [AGSEnvelope envelopeWithXmin:-16.7178 ymin:10.9251 xmax:-13.6439 ymax:12.6847 spatialReference:sr];
    [self.mapView zoomToEnvelope:env animated:YES];
    gLine.outline.color = [UIColor redColor];
    AGSSimpleFillSymbol *gfxLine = [[[AGSSimpleFillSymbol alloc] init] autorelease];
    gfxLine.outline.color = [UIColor redColor];
    //gLine = (AGSFillSymbol* )gfxLine;
    AGSCompositeSymbol *mainSym = self.sketchLayer.mainSymbol;
            lineColor.outline.color = [UIColor redColor]; //changes line
            lineColor.outline.width = 4; // changes width of line.
-(void)makeLine:(CGPoint)touch firstTouch:(BOOL)firstTouch lineFinished:(BOOL)lineFinished
    if (firstTouch)
        //poly = [[AGSMutablePolyline alloc] initWithSpatialReference:self.mapView.spatialReference];
        //self.sketchLayer.geometry = [[[AGSMutablePolyline alloc]initWithSpatialReference:self.mapView.spatialReference]autorelease];
        [poly addPathToPolyline];
        //polly = [[[AGSMutablePolyline alloc] initWithSpatialReference:self.mapView.spatialReference]autorelease];
    [poly addPointToPath:[self.mapView toMapPoint:touch]];
    self.sketchLayer.geometry = poly;
-(void) mapView:(AGSMapView *) mapView failedLoadingLayerForLayerView:(UIView<AGSLayerView> *)layerView baseLayer:(BOOL)baseLayer withError:(NSError *)error
    if (!baseLayer)
        [self.mapView removeMapLayerWithName:layerView.name];
- (void)viewDidUnload
    [self setMapView:nil];
    [self setPainting:nil];
    [self setColorPicker:nil];
    [self setColorPalette:nil];
    [super viewDidUnload];
    // Release any retained subviews of the main view.
-(void)dealloc
    [painting1 release];
    self.mapView = nil;
    self.toolbar = nil;
    self.sketchToolbar = nil;
    [super dealloc];
- (BOOL)shouldAutorotateToInterfaceOrientation:(UIInterfaceOrientation)interfaceOrientation
    return YES;
- (IBAction)pullPaintBoard:(id)sender {
    CGRect redLiningFrame = painting.frame;
    CGRect colorFrame = colorPalette.frame;
    if (redLiningFrame.origin.x == 0)
        redLiningFrame.origin.x = 1024;
        colorFrame.origin.x = 1024;
        //gLine.outline.color = lineColor.outline.color;
        AGSGraphic* graphic = [AGSGraphic graphicWithGeometry:sketchGeometry symbol:lineColor attributes:nil infoTemplateDelegate:nil];
        [self.graphicsLayer dataChanged];
        [self.sketchLayer clear];
    else
        redLiningFrame.origin.x = 0;
        colorFrame.origin.x = 60;
    painting.frame = redLiningFrame;
    colorPalette.frame = colorFrame;
- (IBAction)colorPicker:(id)sender {
- (IBAction)selectRed:(id)sender {
- (IBAction)selectBlue:(id)sender {
    gLine.outline.color = [UIColor blueColor];
- (IBAction)clearScreen:(id)sender {
    [self.graphicsLayer removeAllGraphics];
@end
edited code slightly to add lines to graphic layer.
lines are created in my makeLine method. they are added to the graphic layer in the pullPaintBoard method.
NimeshJarecha
Please attach an application which I can run. It's very hard to read the code and help you.
Regards,
Nimesh
