Symbols Not Showing When Graduated Symbols Selected
556
08-28-2012 01:30 PM
KyleGochenour
Preface, still new to ArcMap.
I am using ArcMap 10.0 to create a map showing fill removal. I have a layer with stations where fill was removed and have the weight added to each station in the attribute table.
I can make Graduated Colors symbols just fine and get different colors based on the Weight field and it looks great.
But when I change to Graduated Symbols based on the Weight field, all the symbols just disappear. The point size is set to go from 10-18, so something _should_ be showing. Normalization is set to none.
Not sure what to check. And let me know what other information would be helpful as well. Thanks!
AugustineJesuraja1
Export the data as a shape file and add the new shape file as a layer in your project. On the new layer, apply graduated symbols - it should work.
rgds
AR Augustine
