manghiec
Printing map with attributes
Discussion created by manghiec on Aug 24, 2012
Latest reply on Aug 29, 2012 by manghiec
Has anyone tried to print a map with attributes of a selected feature?  I've managed to use the Print Task to create the map image and moved all of the attribute data from the selected feature to a series of <p> tags (there's probably a better way but I'm still learning!).  I'm using the window.print() command to print the webpage.  It comes out okay, but not idea.  Is there a server-side solution to this?  I may also use cookies to store the url of the Print Result and the attribute array.
Outcomes
