import arcpy from arcpy import env from arcpy import mapping env.workspace = r"C:\temp\python" mxd = mapping.MapDocument(r"C:\Temp\Sample.mxd") df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0] for lyr in arcpy.mapping.ListLayers(mxd): lyr.visible = True fc = r"C:\Temp\Grid.shp" count = str(arcpy.GetCount_management(fc)) x = 0 while x < int(count) + 1: rows = arcpy.SearchCursor(fc, "FID = " + str(x)) for row in rows: df.zoomToSelectedFeatures() df.extent = lyr.getSelectedExtent() arcpy.RefreshActiveView() mapping.ExportToJPEG(mxd, r"C:\Temp\Map_" + str(x) + ".jpg", df, df_export_width=3004, df_export_height=2125, world_file=True) print('Exported image',x, 'of', count) x += 1 print("MXD to JPEGs Export successful") print("Thank you!")
Solved! Go to Solution.
import arcpy from arcpy import env from arcpy import mapping env.workspace = r"C:\temp" ###modified this too because I put the shapefile and MXD in the same folder called temp mxd = mapping.MapDocument(r"C:\Temp\Sample.mxd") df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0] for lyr in arcpy.mapping.ListLayers(mxd): lyr.visible = True fc = r"C:\Temp\Grid.shp" count = str(arcpy.GetCount_management(fc)) x = 0 while x < int(count) + 1: rows = arcpy.SearchCursor(fc, "FID = " + str(x)) arcpy.SelectLayerByAttribute_management(lyr, "NEW_SELECTION", "FID = " + str(x)) ######Added this line for row in rows: df.zoomToSelectedFeatures() df.extent = lyr.getSelectedExtent() arcpy.RefreshActiveView() mapping.ExportToJPEG(mxd, r"C:\Temp\Map_" + str(x) + ".jpg", df, df_export_width=3004, df_export_height=2125, world_file=True) print('Exported image',x, 'of', count) x += 1 print("MXD to JPEGs Export successful") print("Thank you!")
import arcpy mxd = arcpy.mapping.MapDocument(r"C:\Temp\Sample.mxd") df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0] lyr = arcpy.mapping.ListLayers(mxd, "grid")[0] ##shapefile layer name called grid rows = arcpy.SearchCursor(lyr) x=1 for row in rows: df.extent = row.Shape.extent arcpy.mapping.ExportToJPEG(mxd, r"C:\Temp\Map_" + str(x) + ".jpg", df, df_export_width=3004, df_export_height=2125, world_file=True) print x x+=1
import arcpy, os, exceptions, collections print "Starting process " + str(time.ctime()) mxd = arcpy.mapping.MapDocument("CURRENT") df = arcpy.mapping.ListDataFrames(mxd)[0] mapLayers = arcpy.mapping.ListLayers(mxd) out_loc = "\\\\ntdmzgis\\Data\\NameOfFolderHere\\" #TODO: Set the output locations, add as a parameter res = 300 #TODO: this is the output resolution 300 dfWidth = 8 #TODO: this is the width of the dataframe in inches inch_to_meters = 0.0254 #This is the convertion for inches to meters must match the defined coordinate system of the data frame print_pages = [] #TODO: Add pages; example range ['6-8',21,'9-18',36], leave blank to get all pages if mapLayers.count <> 0: for lyr in arcpy.mapping.ListLayers(mxd, "L*", df): #This selects the layer names,make sure they are named L1, L2, etc. Can manually select layer if needed print "Checking if " + lyr.name + " is feature Layer" if lyr.isFeatureLayer == True: print "We found a feature layer" if os.path.exists(out_loc + lyr.name): #print "Folder existed" #Uncomment this line and Comment out next line if you want to overwrite the folder raise Exception ("This " + out_loc + lyr.name + " folder existed! \n Are you sure this is the right location? \n Yes, Please move, rename, or delete to continue...") else: os.makedirs(out_loc + lyr.name) print "A new directory was made at " + out_loc + lyr.name rows = arcpy.SearchCursor(lyr) print "Starting process to make clipped JPEGs for " + lyr.name + " " + str(time.ctime()) d = len(print_pages) if d <= 0: rows1 = arcpy.SearchCursor(lyr) for rw in rows1: print_pages.append(rw.getValue("PageNumber")) if [el for el in print_pages if isinstance(el, collections.Iterable) and ('-' in el)]: print "We have a range" for p in range(d): print str(p) + " of " + str(d) if print_pages .find("-"): l = print_pages m = l.partition("-")[0] n = l.partition("-")[2] del print_pages for o in range(int(m),int(n)+1): print_pages.append(o) del l, m, n, o else: print "No range selected" print print_pages for row in rows: pg = row.getValue("PageNumber") if pg in print_pages: df.extent = row.Shape.extent print "Feature Extent: " + str(row.Shape.extent) print "Selected scale: " + str(df.scale) xmin, ymin, xmax, ymax = row.shape.extent.XMin, row.shape.extent.YMin, row.shape.extent.XMax, row.shape.extent.YMax xWidth = xmax - xmin yHeight = ymax - ymin featSq = math.sqrt(math.pow(xWidth,2) + math.pow(yHeight,2)) dfSq = math.sqrt(math.pow(df.elementWidth * inch_to_meters,2) + math.pow(df.elementHeight * inch_to_meters,2)) #Calculates the needed scale to fit image into dataframe size if mxd.activeView != 'PAGE_LAYOUT' : df.scale = (featSq / dfSq) * 0.651951975 else: df.scale = (featSq / dfSq) print "Using scale for " + mxd.activeView print "Adj. scale: " + str(df.scale) #Set the size of the dataframe to match the feature df.elementWidth = dfWidth df.elementHeight = dfWidth * (yHeight/xWidth) df.elementPositionX, df.elementPositionY = 0, 0 print "DF Width: " +str(df.elementWidth) + " x Height: " + str(df.elementHeight) #Set the pixel size based on the resolution df = arcpy.mapping.ListDataFrames(mxd)[0] picWidth = long(df.elementWidth * res) picHeight = long(df.elementHeight * res) print "Image Width: " +str(picWidth) + " x Height: " + str(picHeight) print "Working on row..." + str(row.getValue("PageNumber")) + " at " + str(time.ctime()) arcpy.RefreshActiveView() arcpy.mapping.ExportToJPEG(mxd, out_loc + lyr.name + "\\" + str(row.getValue("PageNumber")) + ".jpg", df, df_export_width= picWidth, df_export_height=picHeight, resolution=res, world_file=True) print "Finished row..." + str(row.getValue("PageNumber")) + " at " + str(time.ctime()) print lyr.name + " JPEGs have been made at " + str(time.ctime()) else: print lyr.name + " was not a Feature Class" try: lyr except: del mxd, df, mapLayers, out_loc, res, dfWidth, inch_to_meters raise Exception ("Check the layer Name in line 12 is actually in the map.") else: raise Exception ("No layers were in map.") print "Creating web cache completed " + str(time.ctime()) #clean up our varibles del mxd, df, mapLayers, out_loc, res, dfWidth, inch_to_meters, lyr, rows, row, print_pages, xmin, ymin, xmax, ymax, xWidth, yHeight, featSq, dfSq, picWidth, picHeight, p,rows1, rw
