Landmarks in Network Analyst 10.1
1897
08-22-2012 11:30 AM
EricStipe
New Contributor III
I have been trying to implement the landmark functionality into route solving in Network Analyst using 10.1. I have added a point class as turn landmarks (as well as playing around with confirmation landmarks as well), verified they have a valid name field, and adjusted the tolerance, yet the landmarks are not showing up in the directions. Am I missing something?
Eric
EricStipe
New Contributor III
If anyone has gotten these to work any information at all would be greatly appreciated.
ERic
EricStipe
New Contributor III
Turns out if you want the landmarks to be shown in the directions, you must use the geoprocessing tool found in Arc Toolbox>Network Analyst Tools>Analysis>Directions and set the style to NA Campus. The output directions will have the landmarks included. However now I am tweaking things to see if I can get it not to repeat the same landmark in each segment 4 times.
