Polyline intersect on polygon edge
2984
6
08-16-2012 08:05 AM
DanielLaidlaw
I have a polyline that passes through a polygon, I???m trying to get the two intersect points on the polygon edge. If I try to get the fist and last of what is returned for the intersect point collection I get inconsistent results.
Does anyone have some input as what I might be doing wrong?  I have my code block below.
Appreciate the help
vb
  Polyline outGeometry = new Polyline();
            IGeometryCollection geometryCollection = null;
  if(geometryCollection == null) {
   IGeometryBag geometryBag = new GeometryBag();
   geometryCollection = (IGeometryCollection) geometryBag;
   geometryBag.setSpatialReferenceByRef(mySpatialRef));
            // union all your polylines
  for(int i=0; i<featureList.size(); i++) {
   geometryCollection.addGeometry(featureList.get(i).getShape(), null, null);
  outGeometry.constructUnion((IEnumGeometry) geometryCollection);
  ((ITopologicalOperator) outGeometry).simplify();
  ITopologicalOperator topo ;
  geometry = ((ITopologicalOperator)geometry).getBoundary();
  topo = (ITopologicalOperator)geometry  ;
IGeometry intersects = topo.intersect((IGeometry) outGeometry,    esriGeometryDimension.esriGeometry0Dimension);
  IPointCollection Pts = (IPointCollection)intersects;
  for (int j=0;j<Pts.getPointCount();j++){
   tempIntersectPointList.addPoint(Pts.getPoint(j), null, null);
firstPointOnEdge = tempIntersectPointList.getPoint(0)
secondPointOnEdge = tempIntersectPointList.getPoint(tempIntersectPointList.getPointCount() - 1),
KenBuja
MVP Esteemed Contributor
The way I worked with multiple points from an intersection in one of my applications was to use IGeometryCollection, since the intersection returns a multipoint geometry instead of a point geometry. When I tested for overlapping polygons or lines sharing segments, I used IGeometry instead. This shows how I write the intersections to a point feature class.
Dim pOverlapGeometryCollection As ESRI.ArcGIS.Geometry.IGeometryCollection = pTopoOp.Intersect(pInGeometry, ESRI.ArcGIS.Geometry.esriGeometryDimension.esriGeometry0Dimension)
If pOverlapGeometryCollection IsNot Nothing Then
    For j As Integer = 0 To pOverlapGeometryCollection.GeometryCount - 1
        pOverlapGeometry = pOverlapGeometryCollection.Geometry(j)
        pOverlapFeature = pOverlapBuffer
        pOverlapFeature.Shape = pOverlapGeometry
        pOverlapFeature.Value(pOverlapFeature.Fields.FindField(Field1)) = pFeature.OID
        pOverlapFeature.Value(pOverlapFeature.Fields.FindField(Field2)) = pSelFeature.OID
        pOverlapFCursor.InsertFeature(pOverlapBuffer)
End If
DanielLaidlaw
I seem to get the intersecting points fine, my only issue is I cant seem to identify the point on the polygon edge. Getting the first and last point on the intersect point collection is not always the point on the edge of the polygon.  That's what I'm still tryingto figure out.
DanielLaidlaw
Another question if someone knows the answer is why do I get so many points when I only use the polygon boundary to intersect the polyline. Shouldn�??t it just be two?
KenBuja
It looks like it returns the points from the top to the bottom. I ran a test using the code below on a polygon and line, flashing each point in the geometry collection. The image below shows the direction the line was digitized by the arrows. The upper right intersection point was flashed first.
Is it a polygon with no internal holes? In the sample I ran, I used a donut polygon, which resulted in four intersections. If you look at the help for Boundary, you'll see that it will return all the rings of a polygon, not just the outside boundary.
            Dim pLayer As ESRI.ArcGIS.Carto.ILayer2
            Dim pLayer1 As ESRI.ArcGIS.Carto.ILayer2
            Dim pFLayer As ESRI.ArcGIS.Carto.IFeatureLayer
            Dim pFClass As ESRI.ArcGIS.Geodatabase.IFeatureClass
            Dim pFCursor As ESRI.ArcGIS.Geodatabase.IFeatureCursor
            Dim pFeature As ESRI.ArcGIS.Geodatabase.IFeature
            Dim pPolygonGeometry As ESRI.ArcGIS.Geometry.IGeometry
            Dim pLineGeometry As ESRI.ArcGIS.Geometry.IGeometry
            Dim pTopoOp As ESRI.ArcGIS.Geometry.ITopologicalOperator
            Dim pOverlapGeometry As ESRI.ArcGIS.Geometry.IGeometry
            Dim pRgbColor As New ESRI.ArcGIS.Display.RgbColor
            Using releaser As New ESRI.ArcGIS.ADF.ComReleaser
                releaser.ManageLifetime(pFCursor)
                pLayer = My.ArcMap.Document.FocusMap.Layer(0)
                pFLayer = New ESRI.ArcGIS.Carto.FeatureLayer
                pFLayer = pLayer
                pFClass = pFLayer.FeatureClass
                pFCursor = pFClass.Search(Nothing, False)
                pFeature = pFCursor.NextFeature
                pLineGeometry = pFeature.Shape
                pLayer1 = My.ArcMap.Document.FocusMap.Layer(1)
                pFLayer = pLayer1
                pPolygonGeometry = pFeature.Shape
                pTopoOp = pPolygonGeometry
                pOverlapGeometryCollection = pTopoOp.Intersect(pLineGeometry, ESRI.ArcGIS.Geometry.esriGeometryDimension.esriGeometry0Dimension)
                MsgBox(pOverlapGeometryCollection.GeometryCount)
                pRgbColor.Red = 255
                    FlashGeometry(pOverlapGeometry, pRgbColor, My.ArcMap.Document.ActiveView.ScreenDisplay, 500) ' this is an ArcGIS snippet
           End Using
[ATTACH=CONFIG]17019[/ATTACH]
DanielLaidlaw
Its all comming together , yes I have a polygon with no internal holes. I though the getBoundary() returns a polygon with the donut hole...  So my question would be how do I get just the external ring of the polygon?
vb
KenBuja
Try the IPolygon4::ExteriorRingBag
Dim pPolygon As ESRI.ArcGIS.Geometry.IPolygon4 = pPolygonGeometry
Dim pGeoBag As ESRI.ArcGIS.Geometry.IGeometryBag = pPolygon.ExteriorRingBag
Dim pGeoCollection As ESRI.ArcGIS.Geometry.IGeometryCollection = pGeoBag
MsgBox(pGeoCollection.GeometryCount)
