sondickerson
Update the TNSNames file on the SOC machines
Discussion created by sondickerson on Aug 16, 2012
Latest reply on Aug 29, 2012 by weiland00
We added a new oracle database. Then updated the TNSNames file on the SOM machines and started testing it with Map Services.
We were having problems with the following errors:
The Layer:'Counties' in Map:'Data Layers' is invalid. The base table definition string "NEWSCHEMA.COUNTIES" is invalid. Underlying DBMS error [ORA-12154: TNS:could not resolve the connect identifier specified No extended error.].
It would work sometimes but other times, not.  We missed the step to update the TNSNames files on other SOC machines.  Hopefully this will help you if you run into a similar situation.
Outcomes
