sebastian_4m
Empty output after cellstatistics in arcpy
Discussion created by sebastian_4m on Aug 14, 2012
Latest reply on Aug 14, 2012 by curtvprice
I am running cellstatistics in arcpy and I'm getting an empty output (values -3.40282e+038 to 3.40282e+038).  I have ran this script in the past with good results and now suddenly it stopped working
import arcpy
from arcpy.sa import *
from arcpy import env
# Variables to set
extent = "C:\\Users\\Sebastian\\Documents\\miami2\\boundaries.gdb\\cutter"
snapTo = "C:\\Users\\Sebastian\\Documents\\miami2\\cost.gdb\\ras"
sourceWorkspace = "C:\\Users\\Sebastian\\Documents\\miami2\\_0406.gdb"
targetWorkspace = "C:\Users\Sebastian\Documents\miami2\heatmaps"
nameOut = '_0406_'
#ArcPy environment settings
arcpy.env.workspace = sourceWorkspace
arcpy.env.snapRaster = snapTo
arcpy.env.extent = extent
arcpy.env.mask = extent
arcpy.env.scratchWorkspace = "C:\\Users\\Sebastian\\Documents\\miami2\\scratch.gdb"
# Check out the ArcGIS Spatial Analyst extension license
# Create list of rasters
rasterList = arcpy.ListRasters("_*")
print rasterList
# Calculates cell statistics
outStats = CellStatistics(rasterList, "SUM", "NODATA")
# Saves the output
outStats.save(targetWorkspace+"\\"+nameOut)
all the inputs, snap raster, mask and extent(FC) are in the same coordinate system.
Please any help would be greatly appreciated
Outcomes
