Solved! Go to Solution.
Can you post some code to reproduce what you're seeing? I'm guessing the argument you're passing to GraphicsLayer.remove() isn't a graphic.
Here's a simple page that shows using GraphicsLayer.remove(): http://jsfiddle.net/RsbD2/
function showSelection(featureSet) { //remove all the selectedGraphics from the map, unless the CTRL key is pressed, leaving any drawnGraphics on the map if (!selectEvent.ctrlKey) { selectedGraphics.clear(); accounts = []; } //QueryTask returns a feature set. Loop through the featureset and add them to the map dojo.forEach(featureSet.features, function(feature){ var graphic = feature; //add the feature if it is not already in the collection if (accounts.indexOf(feature.attributes.ACCT) == -1) { accounts.push(feature.attributes.ACCT); graphic.setSymbol(symbol); //add the graphic to the selectedGraphics layer selectedGraphics.add(graphic); } else { accounts.splice(accounts.indexOf(feature.attributes.ACCT),1); selectedGraphics.remove(graphic); } }); }
Are you sure you're getting to selectGraphics.remove()? Try putting a console.log("removed graphic"); after selectGraphics.remove(). I ask because I think you're using array.splice incorrectly. Check out the MDN doc for more info: https://developer.mozilla.org/en-US/docs/JavaScript/Reference/Global_Objects/Array/splice
Taking a closer look at this, graphic is a reference to a feature returned from a query task, meaning that it isn't actually in your graphics layer yet. You need to find the graphic in selectedGraphics.graphics with a particular ACCT value and pass that to selectedGraphics.remove(). I would use dojo.filter or maybe dojo.some with selectedGraphics.graphics to do this.
function showSelection(featureSet) { //remove all the selectedGraphics from the map, unless the CTRL key is pressed, leaving any drawnGraphics on the map if (!selectEvent.ctrlKey) { selectedGraphics.clear(); accounts = []; } //QueryTask returns a feature set. Loop through the featureset and add them to the map dojo.forEach(featureSet.features, function(feature){ var graphic = feature; //add the feature if it is not already in the collection if (accounts.indexOf(feature.attributes.ACCT) == -1) { accounts.push(feature.attributes.ACCT); graphic.setSymbol(symbol); //add the graphic to the selectedGraphics layer selectedGraphics.add(graphic); } else { accounts.splice(accounts.indexOf(feature.attributes.ACCT),1); //get the graphic that matches the feature var filteredGraphics = dojo.filter(selectedGraphics.graphics, function(item) { return item.attributes.ACCT == feature.attributes.ACCT; }) graphic = filteredGraphics[0]; selectedGraphics.remove(graphic); } }); }
