RE: absolute minimum value selection
316
5
08-08-2012 08:07 AM
LarissaPizzolato
I have a file geodatabase table with a field titled "min_value". Within this field there are values from -1000 to +1000. I am trying to search all of the rows in the table to select the row with the lowest absolute value within the "min_value" field (ie. value +/- closest to zero). I will then be using a value (shapefile name) within the same row (but different field) to identify which shapefile to use in the next processing step of the script.
Any help is greatly appreciated!
Thank-you!
MathewCoyle
There may be a better way, but here's the best solution I could find.
curs =  arcpy.SearchCursor(table) for row in curs:     listing.append(row.min_value)  print min((abs(0 - i), i) for i in listing)[1]
You could also pass the OID or some other identifier to go back to the row object.
MathewCoyle
curtvprice
MVP Esteemed Contributor
Matt - I guess I have a tweak:
tv = arcpy.MakeTableView(table)
curs =  arcpy.SearchCursor(tv)
listing = list() # create a list
for row in curs:
del row, curs # always a good idea when done!
xmin = min([abs(i) for i in listing])
# now get that record (or the first if several) with that abs value
curs = SearchCursor(tv,"abs(%s) = %s" % (min_value,xmin))
# get the value for field "shapefile"
shapefile = curs.next().shapefile
del curs
MathewCoyle
for row in curs:
del curs
Looks good, much more fleshed out. Maybe I am missing something though, this doesn't seem to preserve the negative sign with the xmin assignment.
curtvprice
You're right--it doesn't preserve the sign.
I don't think you need it as long as you use the ABS function in the second SearchCursor SQL expression.
Arc 10 help: SQL reference for query expressions used in ArcGIS
MathewCoyle
Ah yes, makes sense. Doesn't really matter if they are positive or negative if they are the same absolute value anyways.
