I've created a sample web page that demonstrates this problem. I've hijacked the Print Dijit example to demonstrate the issue:<!doctype html>
<html lang="en">
<head>
<meta charset="utf-8">
<meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
<title></title>
<link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.1/js/dojo/dijit/themes/nihilo/nihilo.css">
<style type="text/css">
html, body {
height: 100%; width: 100%;
margin: 0; padding: 0;
body{
background-color: #fff; overflow:hidden;
font-family: sans-serif;
label {
display: inline-block;
padding: 5px 5px 0 5px;
font-weight: 400;
font-size: 12pt;
#header {
padding-top: 4px;
padding-right: 15px;
color: #444;
font-size:16pt; text-align:right;font-weight:bold;
height:55px;
background: #fff;
border-bottom: 1px solid #444;
#subheader {
font-size:small;
color: #444;
text-align:right;
padding-right:20px;
#header, #subheader {
text-shadow: 1px 1px 1px #cee1f0;
filter: dropshadow(color=#cee1f0, offx=1, offy=1);
#rightPane{
margin: 0;
padding: 10px;
color: #421b14;
width: 180px;
.ds { background: #000; overflow: hidden; position: absolute; z-index: 2; }
#ds-h div { width: 100%; }
#ds-l div, #ds-r div { height: 100%; }
#ds-r div { right: 0; }
#ds .o1 { filter: alpha(opacity=10); opacity: .1; }
#ds .o2 { filter: alpha(opacity=8); opacity: .08; }
#ds .o3 { filter: alpha(opacity=6); opacity: .06; }
#ds .o4 { filter: alpha(opacity=4); opacity: .04; }
#ds .o5 { filter: alpha(opacity=2); opacity: .02; }
#ds .h1 { height: 1px; }
#ds .h2 { height: 2px; }
#ds .h3 { height: 3px; }
#ds .h4 { height: 4px; }
#ds .h5 { height: 5px; }
#ds .v1 { width: 1px; }
#ds .v2 { width: 2px; }
#ds .v3 { width: 3px; }
#ds .v4 { width: 4px; }
#ds .v5 { width: 5px; }
/* make all dijit buttons the same width */
.dijitButton .dijitButtonNode, #drawingWrapper {
width: 160px;
</style>
<script>var dojoConfig = { parseOnLoad: true };</script>
<script src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.1"></script>
<script>
dojo.require("dijit.layout.BorderContainer");
dojo.require("dijit.layout.ContentPane");
dojo.require("dijit.form.Button");
dojo.require("dijit.form.CheckBox");
dojo.require("esri.map");
dojo.require("esri.toolbars.draw");
dojo.require("esri.dijit.Print");
var app = {};
app.map = null, app.toolbar = null, app.circle = false, app.symbols = null,
app.printer = null;
function init() {
esri.config.defaults.io.proxyUrl = "/arcgisserver/apis/javascript/proxy/proxy.ashx";
var initialExtent = new esri.geometry.Extent({"xmin":-10399332,"ymin":3440549,"xmax":-9801289,"ymax":3705938,"spatialReference":{"wkid":102100}});
app.map = new esri.Map("map", {
extent: initialExtent,
wrapAround180: true
dojo.connect(app.map, 'onLoad', function() {
dojo.connect(dijit.byId('map'), 'resize', app.map, app.map.resize);
app.toolbar = new esri.toolbars.Draw(app.map);
dojo.connect(app.toolbar, "onDrawEnd", addToMap);
// print dijit
app.printer = new esri.dijit.Print({
map: app.map,
url: "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export%20Web%20Map%20Task"
}, dojo.byId("printButton"));
app.printer.startup();
var url = "http://services.arcgisonline.com/ArcGIS/rest/services/Ocean_Basemap/MapServer";
var tiledLayer = new esri.layers.ArcGISTiledMapServiceLayer(url, { "id": "Ocean" });
app.map.addLayer(tiledLayer);
//--Testing----Testing----Testing----------------------------------------------------------
// Save that layer!! We need to save the layer object so we can remove and re-add it later
app.tiledLayer = tiledLayer;
// add census boundary dyn map svc
var dynUrl = "http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer";
var dynLayer = new esri.layers.ArcGISDynamicMapServiceLayer(dynUrl, { "id": "Boundaries" });
app.map.addLayer(dynLayer);
// create a check box
dojo.forEach(["Boundaries", "Ocean"], function(id) {
new dijit.form.CheckBox({
id: "cb_" + id,
name: "cb_" + id,
checked: true,
onChange: function(bool) {
bool ?
app.map.getLayer(this.id.split('_')[1]).show() :
app.map.getLayer(this.id.split('_')[1]).hide();
}, dojo.create('input', { id: 'lyr_' + id })).placeAt(dojo.byId('layerToggle'));
// create a label for the check box
var label = dojo.create('label', {
"for": "cb_" + id,
"innerHTML": id
dojo.place(label, dojo.byId('layerToggle'));
dojo.place(dojo.create('br'), dojo.byId('layerToggle'));
// set up symbols for the various geometry types
app.symbols = {};
var es = esri.symbol;
var dc = dojo.Color;
// find the divs for buttons
dojo.forEach(dojo.query(".drawing"), function(btn) {
var button = new dijit.form.Button({
label: btn.innerHTML,
onClick: function() {
activateTool(this.id);
style: { "width": "100%", "margin": "3px auto", "textAlign": "center" }
}, btn);
//--Testing----Testing----Testing------------------------------------------------------------
// Make the Base Layer Go Away
function activateTool(type) {
// Hijack drawing tool to activate our disappearing base map layer issue
app.map.removeLayer(app.tiledLayer)
app.map.addLayer(app.tiledLayer)
function addToMap(geom) {
dojo.ready(init);
</script>
</head>
<body class="nihilo">
<div id="mainWindow"
data-dojo-type="dijit.layout.BorderContainer"
data-dojo-props="design:'headline',gutters:false"
style="width: 100%; height: 100%; margin: 0;">
<div id="header"
data-dojo-type="dijit.layout.ContentPane"
data-dojo-props="region:'top'">
Print Dijit: Hijacked application to show Disappearing Base Layer Issue
<div id="subheader">Requires ArcGIS Server 10.1</div>
</div>
<div id="map" class="shadow"
data-dojo-props="region:'center'">
<!-- drop shadow divs -->
<div id="ds">
<div id="ds-h">
<div class="ds h1 o1"></div>
<div class="ds h2 o2"></div>
<div class="ds h3 o3"></div>
<div class="ds h4 o4"></div>
<div class="ds h5 o5"></div>
</div>
<div id="ds-r">
<div class="ds v1 o1"></div>
<div class="ds v2 o2"></div>
<div class="ds v3 o3"></div>
<div class="ds v4 o4"></div>
<div class="ds v5 o5"></div>
</div>
</div> <!-- end drop shadow divs -->
</div>
<div id="rightPane"
data-dojo-props="region:'right'">
<div id="printButton"></div>
<hr />
<div id="drawingWrapper">
Make the baselayer go away:
<!-- Testing----Testing----Testing---------------------------------------------------------->
<div id="test" class="drawing">Click Me</div>
</div>
<hr />
<div id="layerToggle">
Toggle Layers: <br />
<!-- checkbox and labels inserted programmatically -->
</div>
</div>
</div>
</body>
</html>
