I met an interesting issue while using "esri.dijit.editing.Editor" class that in esri javascript api 3.0. Essentially, after draw a polygon using "Polygon tool", the attribute inspector pops up. From then on, I can't select any other existing features. It works mostly ok, though, when use "Freehand Polygon" tool to draw a polygon. Except that drawing with "Freehand Polygon" tool stops panning activity. Same problem happens to one of esri editor sample:
