Hi Jason,
Could you please share part/all of your data? I have posted some questions to the other thread (on same issue) for you - please respond to the questions - that will help me refine my tests and find a good answer for you.
Thanks, Nobbir
Geoprocessing Team
Thanks for the data 🙂
I guess your input to Find Identical is Data_Split_Lines_By_Vertices, right? Here is the screenshot for one of the self-intersecting lines (feat# 5 of your Test_Lines data):
[ATTACH=CONFIG]19907[/ATTACH]
After splitting this line by vertices, we get 17 short lines.
[ATTACH=CONFIG]19909[/ATTACH]
None of these 17 lines lie exactly one upon another - that is, there is no spatially duplicate feature among these 17 lines. Could you share your spatially identical lines?
Wouldn't a line that starts at vertex 0, goes out to vertex 1, then returns to vertex 0 and closes as vertex 2 (and vertex 2 lies on top of vertex 0 by setting the snapping environment appropriately) be identical by definition?
Yes, the answer is "should be". However, in 10.0 (including SP5), digitizing direction mattered. So, the above two lines are considered non-identical 😞 We have enhanced the tool's behavior by ignoring the digitizing direction in 10.1.
Let me know if you need a workaround. If you want to try - just look the documentation for ArcPy Geometry classes. There is a method called equals - try using that.
Earlier, I was unable to reproduce the case as I was using a 10.1 setup. 😞
