I am new and piecing together samples to get this to work. What do i put in the attribute section for new graphic. Here is the function in question. Let me know if you need the entire script.
function onGeocodesuccess(results)
console.log(results);
//alert(results.score.toString);
var geoPoint = new esri.geometry.Point(results.utm_x, results.utm_y, map.spatialReference);
var symbol = new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_CIRCLE, 15, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([0,0,255]), 2), new dojo.Color([0,0,255]));
var infoTemplate = new esri.InfoTemplate("Attributes", "${*}");
var graphic = new esri.Graphic(geoPoint, symbol, attr, infoTemplate);
map.graphics.add(graphic);
map.infoWindow.setTitle(graphic.getTitle());
map.infoWindow.setContent(graphic.getContent());
var screenPnt = map.toScreen(geoPoint);
map.infoWindow.show(screenPnt,map.getInfoWindowAnchor(screenPnt));
Thanks so much for your time and help.
