Solved! Go to Solution.
removal_data = {'Field Beans':[11.0,11.0,12.0,12.0]}
def get_val(dname,key,col_idx): d_cols = dname[key] return d_cols[col_idx]
J29 = 10 #some number provided by user input or derived from some other process in your code J28 = 'Field Beans' #again, how this is supplied is a matter of how the overall program will work - user input or from some other process inside the program, this could be based on a list of the keys in a given dictionary for instance result = J29 * (get_val(removal_data,J28,2))
rows = arcpy.UpdateCursor(FeatureClass,'','','updateField') for row in rows: if row.updateField == 1: row.updateField = *some calculation* rows.updateRow(row) elif row.updateField == 2: row.updateField = *some calculation* rows.updateRow(row) elif ...another condition to test for..
if row.updateField in (1,5,10,11) :
