dale@thani
Recordsets
Discussion created by dale@thani on Jul 25, 2012
I am trying to do the following:
Recordset -> Bearing Distance to Line -> Shp file.
I am using the interactive recordset variable and I can manually enter values in fine but when I run the tool it produces no line.
If I use an existing table (the same table as the import schema) with the same values entered in it works fine and produces a line.
How are the Interactive Records different from Using Records from a dbf file.
Any help will be appreciated.
Outcomes
