Calculate Direction/Angle of Polyline Feature Class Relative to North
3239
07-24-2012 04:35 PM
DarrochKaye
I am working with some cyclone data and I have plotted various tracks from a number of events. I would like to know the angle/direction of each segment of the line and I am unsure the best way to do this. Due to the nature of the data, it is imperative the angle must be in degrees relative to north, i.e. north = zero degrees.
I found this code below on another thread but it seems to be giving me the wrong results, e.g. a line which should have an angle of 180 degrees is calculated as 90 degrees, and another which should be around 60 degrees is 209 degrees - as you can see the error isn't consistent therefore I doubt it is the 180 variable as displayed in the code:
180 + math.atan2((!Shape.lastpoint.Y! - !Shape.firstpoint.Y!),(!Shape.lastpoint.X! - !Shape.firstpoint.X!)) * (180 / math.pi)
I am a Python novice (attending ESRI training course soon) but I do have XML and HTML code experience, so any help would be greatly appreciated.
DK
Pierre-LucBoivin
You can try this formula :
It's works great for me
def NorthAzimuth(Pline):
 degBearing = math.degrees(math.atan2((Pline.lastPoint.X - Pline.firstPoint.X),(Pline.lastPoint.Y - Pline.firstPoint.Y)))
 if (degBearing < 0) :      degBearing += 360.0
 return degBearing
DarrochKaye
 return degBearing
Thanks for the reply. Unfortunately when I paste this into the Field Calculator I get a generic error prompt: "There was a failure during geoprocessing, check the Geoprocessing Results window for details." But there is no record of this task in the results pane.
Thanks for your help.
DK
JayHalligan
New Contributor III
Parser:
Python
Expression:
GetAzimuthPolyline(!Shape!)
def GetAzimuthPolyline(shape):
 degBearing = (math.degrees(math.atan2((shape.lastPoint.X - shape.firstPoint.X),(shape.lastPoint.Y - shape.firstPoint.Y))))+90
 return degBearing
This will return all + degrees with 0 degrees starting from the North rotating clockwise
