Solved! Go to Solution.
Unfortunately you probably won't be able to get any JSON from the printing process as soon as you click the button, it'll lock the browser up with an "unresponsive script" response. I.E will report stack issues. With firebug closed (not recording) the button will change to "printing" but nothing will print and the button stays like that until you refresh the page again.
var items = dojo.map(results, function (result) { var graphic = result.feature; var sms = esri.symbol.SimpleMarkerSymbol; var sls = esri.symbol.SimpleLineSymbol; graphic.setSymbol( new sms( "circle", 14, new sls("solid", new dojo.Color([6, 105, 140]), 1), new dojo.Color([6, 105, 140, 0.5]) ) ); app.map.graphics.add(graphic); return dojo.clone(graphic.attributes); });
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd"> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8" /> <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9" /> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=yes"/> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.1/js/dojo/dijit/themes/soria/soria.css"/> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.1/js/dojo/dojox/grid/resources/Grid.css"/> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.1/js/dojo/dojox/grid/resources/soriaGrid.css"/> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.1/js/esri/dijit/css/Popup.css"/> <link rel="stylesheet" type="text/css" href="https://community.esri.com/css/beacon.css" /> <link rel="stylesheet" type="text/css" href="https://community.esri.com/css/tabs.css" /> <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } #map { padding:0; } </style> <script type="text/javascript"> dojoConfig = { parseOnLoad: true, locale: "en-gb" } </script> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.1"></script> <script type="text/javascript"> dojo.require("esri.map"); dojo.require("dijit.form.Button"); dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("dijit.layout.TabContainer"); dojo.require("dijit.Toolbar"); dojo.require("dojox.grid.DataGrid"); dojo.require("dojo.data.ItemFileReadStore"); dojo.require("dojo.data.ItemFileWriteStore"); dojo.require("esri.dijit.Print"); dojo.require("esri.tasks.find"); var app = {}; app.printUrl = "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export%20Web%20Map%20Task"; function init() { esri.config.defaults.io.proxyUrl = "/arcgisserver/proxy/proxy.ashx"; app.map = new esri.Map("map", { extent: new esri.geometry.Extent({ "xmin": 1073230, "ymin": 4793770, "xmax": 1514290, "ymax": 4960990, "spatialReference": { "wkid": 2193 } }), logo: false, wraparound180: true }); var baseMapLayer = new esri.layers.ArcGISTiledMapServiceLayer("http://services.arcgisonline.co.nz/ArcGIS/rest/services/Generic/newzealand/MapServer"); app.map.addLayer(baseMapLayer); dojo.connect(app.map, 'onLoad', function () { dojo.connect(dijit.byId('map'), 'resize', app.map, app.map.resize); var printMap = esri.request({ "url": app.printUrl, "content": { "f": "json" } }); printMap.then(print, error); }); } function print(p) { var template = new esri.tasks.PrintTemplate(); template.layout = "A4 Landscape"; template.format = "pdf"; template.layoutOptions = { "authorText": "", "copyrightText": "Copyright " + new Date().getFullYear(), "titleText": "Groundwater", "scalebarUnit": "Kilometers" }; printer = new esri.dijit.Print({ "map": app.map, "templates": [template], url: app.printUrl }, dojo.byId("print")); printer.startup(); } function doFind() { var s = dojo.byId("query").value var findParams = new esri.tasks.FindParameters(); var findTask = new esri.tasks.FindTask("http://gis.es.govt.nz/ArcGIS/rest/services/Groundwater/MapServer"); findParams.layerIds = [0]; findParams.searchFields = ["Well_No"]; findParams.returnGeometry = true; findParams.outSpatialReference = app.map.spatialReference; findParams.searchText = s; findTask.execute(findParams, showResults); } function error(err) { alert("Error: " + err); } function showResults(results) { app.map.graphics.clear(); if (results.length > 0) { var items = dojo.map(results, function (result) { var graphic = result.feature; var sms = esri.symbol.SimpleMarkerSymbol; var sls = esri.symbol.SimpleLineSymbol; graphic.setSymbol( new sms( "circle", 14, new sls("solid", new dojo.Color([6, 105, 140]), 1), new dojo.Color([6, 105, 140, 0.5]) ) ); app.map.graphics.add(graphic); return dojo.clone(graphic.attributes); }); console.log("items: ", items); var data = { 'identifier': 'OBJECTID', 'items': items } var store = new dojo.data.ItemFileReadStore({ data: data }); var grid = new dojox.grid.DataGrid({ 'id': 'grid', 'store': store, 'structure': [{ 'name': 'Well Number', 'field': 'WELL_NO', 'width': '200px' }], 'rowSelector': '0px' }); grid.placeAt("records"); grid.startup(); } else { alert("No results found matching your criteria."); } } dojo.ready(init); </script> </head> <body class="soria"> <div data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline'" style="width:100%; height:100%; margin:0;" id="workspace"> <div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'top'" id="header"> <div id="toolbar" data-dojo-type="dijit.Toolbar"> <div id="print"></div> </div> </div> <div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'left'" style="width: 240px;" id="side"> <div dojoType="dijit.layout.TabContainer" id="tabContainer" style="width: 100%; height: 100%;" tabPosition="top"> <div dojoType="dijit.layout.ContentPane" title="Main" id="main"> <h2>Search For...</h2> <div id="search"> <p>Look For:</span> <br/> <input type="text" id="query" style="width: 222px" /> </p> </div> <p>Look In: <br/> <select id="lookIn" style="width: 228px"> <option value="WN">Well Number</option> </select> </p> <p> <button data-dojo-type="dijit.form.Button" data-dojo-props='onClick:function(){ doFind();}, value:"Search"'>Search</button> </p> </div> <div dojoType="dijit.layout.ContentPane" title="Results" id="results"> <div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'left'" style="width: 240px;" id="records"></div> </div> </div> </div> <div id="map" data-dojo-props="region:'center'" data-dojo-type="dijit.layout.ContentPane"></div> </div> </body> </html>
Do you have very complex or large number of graphics on the map?
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd"> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/> <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9" /> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=yes"/> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.1/js/dojo/dijit/themes/soria/soria.css" /> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.1/js/dojo/dojox/grid/resources/Grid.css" /> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.1/js/dojo/dojox/grid/resources/soriaGrid.css" /> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.1/js/esri/dijit/css/Popup.css" /> <link rel="stylesheet" type="text/css" href="https://community.esri.com/css/beacon.css" /> <link rel="stylesheet" type="text/css" href="https://community.esri.com/css/tabs.css" /> <script type="text/javascript">dojoConfig = { parseOnLoad:true, locale:"en-gb" }</script> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.1"></script> <script type="text/javascript"> dojo.require("esri.map"); dojo.require("dijit.form.Button"); dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("dijit.layout.TabContainer"); dojo.require("dijit.Toolbar"); dojo.require("dojox.grid.DataGrid"); dojo.require("dojo.data.ItemFileReadStore"); dojo.require("dojo.data.ItemFileWriteStore"); dojo.require("esri.dijit.Print"); dojo.require("esri.tasks.find"); var app = {}; app.printUrl = "http://esweb1/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export Web Map Task"; function init() { esri.config.defaults.io.proxyUrl = "/arcgisserver/proxy/proxy.ashx"; app.map = new esri.Map("map", { extent: new esri.geometry.Extent({ "xmin": 1073230, "ymin": 4793770, "xmax": 1514290, "ymax": 4960990, "spatialReference": { "wkid": 2193} }), logo: false, wraparound180: true }); var baseMapLayer = new esri.layers.ArcGISTiledMapServiceLayer ("http://services.arcgisonline.co.nz/ArcGIS/rest/services/Generic/newzealand/MapServer"); app.map.addLayer(baseMapLayer) var service = new esri.layers.ArcGISDynamicMapServiceLayer("http://esweb1/arcgis/rest/services/Public/Groundwater/MapServer", {opacity: this.opacity, id: "emap"}); app.map.addLayer(service); dojo.connect(app.map, 'onLoad', function() { dojo.connect(dijit.byId('map'), 'resize', app.map, app.map.resize); var printMap = esri.request({ "url": "http://esweb1/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export Web Map Task", "content": { "f": "json" } }); printMap.then(print, error); }); } function print(p) { var template = new esri.tasks.PrintTemplate(); template.layout = "A4 Landscape"; template.format = "pdf"; template.layoutOptions = { "authorText": "", "copyrightText": "Copyright " + new Date().getFullYear(), "titleText": "Groundwater", "scalebarUnit": "Kilometers" }; printer = new esri.dijit.Print({ "map": app.map, "templates": [template], url: app.printUrl }, dojo.byId("print")); printer.startup(); } function doFind() { var s = dojo.byId("query").value var findParams = new esri.tasks.FindParameters(); var findTask = new esri.tasks.FindTask("http://esweb1/ArcGIS/rest/services/Public/Groundwater/MapServer"); findParams.layerIds = [0]; findParams.searchFields = ["Well_No"]; findParams.returnGeometry = true; findParams.outSpatialReference = app.map.spatialReference; findParams.searchText = s; findTask.execute(findParams, showResults); } function error(err) { alert("Error: " + err); } function showResults(results) { app.map.graphics.clear(); if (results.length > 0) { var items = dojo.map(results, function(result) { var graphic = result.feature; graphic.setSymbol(new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_CIRCLE, 14, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([6, 105, 140]), 1), new dojo.Color([6, 105, 140, 0.5]) )); app.map.graphics.add(graphic); return graphic.attributes; }); var data = { 'identifier': 'OBJECTID', 'items': items } var store = new dojo.data.ItemFileReadStore({ data: data }); //destroy("grid"); //remove the grid so that the new results are bound fresh var grid = new dojox.grid.DataGrid({ 'id': 'grid', 'store': store, 'structure': [{'name': 'Well Number', 'field': 'WELL_NO', 'width': '200px'}], 'rowSelector': '0px' }); grid.placeAt("records"); grid.startup(); } else { alert("No results found matching your criteria."); } } dojo.ready(init); </script> </head> <body class="soria"> <div data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline'" style="width:100%; height:100%; margin:0;" id="workspace"> <div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'top'" id="header"> <div id="toolbar" data-dojo-type="dijit.Toolbar"> <div id="print"></div> </div> </div> <div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'left'" style="width: 240px;" id="side"> <div dojoType="dijit.layout.TabContainer" id="tabContainer" style="width: 100%; height: 100%;" tabPosition="top"> <div dojoType="dijit.layout.ContentPane" title="Main" id="main"> <h2>Search For...</h2> <div id="search"> <p> Look For:</span><br/> <input type="text" id="query" style="width: 222px" /> </p> </div> <p> Look In: <br/> <select id="lookIn" style="width: 228px"> <option value="WN">Well Number</option> </select> </p> <p> <button data-dojo-type="dijit.form.Button" data-dojo-props='onClick:function(){ doFind();}, value:"Search"'>Search</button> </p> </div> <div dojoType="dijit.layout.ContentPane" title="Results" id="results"> <div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'left'" style="width: 240px;" id="records"></div> </div> </div> </div> <div id="map" data-dojo-props="region:'center'" data-dojo-type="dijit.layout.ContentPane"></div> </div> </body> </html>
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd"> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8" /> <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9" /> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=yes"/> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.1/js/dojo/dijit/themes/soria/soria.css"/> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.1/js/dojo/dojox/grid/resources/Grid.css"/> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.1/js/dojo/dojox/grid/resources/soriaGrid.css"/> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.1/js/esri/dijit/css/Popup.css"/> <link rel="stylesheet" type="text/css" href="https://community.esri.com/css/beacon.css" /> <link rel="stylesheet" type="text/css" href="https://community.esri.com/css/tabs.css" /> <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } #map { padding:0; } </style> <script type="text/javascript"> dojoConfig = { parseOnLoad: true, locale: "en-gb" } </script> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.1"></script> <script type="text/javascript"> dojo.require("esri.map"); dojo.require("dijit.form.Button"); dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("dijit.layout.TabContainer"); dojo.require("dijit.Toolbar"); dojo.require("dojox.grid.DataGrid"); dojo.require("dojo.data.ItemFileReadStore"); dojo.require("dojo.data.ItemFileWriteStore"); dojo.require("esri.dijit.Print"); dojo.require("esri.tasks.find"); var app = {}; // app.printUrl = "http://esweb1/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export Web Map Task"; app.printUrl = "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export%20Web%20Map%20Task"; function init() { // esri.config.defaults.io.proxyUrl = "/arcgisserver/proxy/proxy.ashx"; esri.config.defaults.io.proxyUrl = "/~dswingley/esri_js/proxy/proxy.php"; app.map = new esri.Map("map", { extent: new esri.geometry.Extent({ "xmin": 1073230, "ymin": 4793770, "xmax": 1514290, "ymax": 4960990, "spatialReference": { "wkid": 2193 } }), logo: false, wraparound180: true }); var baseMapLayer = new esri.layers.ArcGISTiledMapServiceLayer("http://services.arcgisonline.co.nz/ArcGIS/rest/services/Generic/newzealand/MapServer"); app.map.addLayer(baseMapLayer); console.log("this.opacity: ", this.opactiy); // var service = new esri.layers.ArcGISDynamicMapServiceLayer("http://esweb1/arcgis/rest/services/Public/Groundwater/MapServer", { // opacity: this.opacity, // id: "emap" // }); // app.map.addLayer(service); var dynamicMapServiceLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://services.arcgisonline.co.nz/arcgis/rest/services/LINZ/geotiffs/MapServer", { "opacity": this.opacity }); app.map.addLayer(dynamicMapServiceLayer); dojo.connect(app.map, 'onLoad', function () { dojo.connect(dijit.byId('map'), 'resize', app.map, app.map.resize); var printMap = esri.request({ // "url": "http://esweb1/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export Web Map Task", "url": app.printUrl, "content": { "f": "json" } }); printMap.then(print, error); }); } function print(p) { var template = new esri.tasks.PrintTemplate(); template.layout = "A4 Landscape"; template.format = "pdf"; template.layoutOptions = { "authorText": "", "copyrightText": "Copyright " + new Date().getFullYear(), "titleText": "Groundwater", "scalebarUnit": "Kilometers" }; printer = new esri.dijit.Print({ "map": app.map, "templates": [template], url: app.printUrl }, dojo.byId("print")); printer.startup(); } function doFind() { var s = dojo.byId("query").value var findParams = new esri.tasks.FindParameters(); var findTask = new esri.tasks.FindTask("http://esweb1/ArcGIS/rest/services/Public/Groundwater/MapServer"); findParams.layerIds = [0]; findParams.searchFields = ["Well_No"]; findParams.returnGeometry = true; findParams.outSpatialReference = app.map.spatialReference; findParams.searchText = s; findTask.execute(findParams, showResults); } function error(err) { alert("Error: " + err); } function showResults(results) { app.map.graphics.clear(); if (results.length > 0) { var items = dojo.map(results, function (result) { var graphic = result.feature; graphic.setSymbol(new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_CIRCLE, 14, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([6, 105, 140]), 1), new dojo.Color([6, 105, 140, 0.5]))); app.map.graphics.add(graphic); return graphic.attributes; }); var data = { 'identifier': 'OBJECTID', 'items': items } var store = new dojo.data.ItemFileReadStore({ data: data }); //destroy("grid"); //remove the grid so that the new results are bound fresh var grid = new dojox.grid.DataGrid({ 'id': 'grid', 'store': store, 'structure': [{ 'name': 'Well Number', 'field': 'WELL_NO', 'width': '200px' }], 'rowSelector': '0px' }); grid.placeAt("records"); grid.startup(); } else { alert("No results found matching your criteria."); } } dojo.ready(init); </script> </head> <body class="soria"> <div data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline'" style="width:100%; height:100%; margin:0;" id="workspace"> <div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'top'" id="header"> <div id="toolbar" data-dojo-type="dijit.Toolbar"> <div id="print"></div> </div> </div> <div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'left'" style="width: 240px;" id="side"> <div dojoType="dijit.layout.TabContainer" id="tabContainer" style="width: 100%; height: 100%;" tabPosition="top"> <div dojoType="dijit.layout.ContentPane" title="Main" id="main"> <h2>Search For...</h2> <div id="search"> <p>Look For:</span> <br/> <input type="text" id="query" style="width: 222px" /> </p> </div> <p>Look In: <br/> <select id="lookIn" style="width: 228px"> <option value="WN">Well Number</option> </select> </p> <p> <button data-dojo-type="dijit.form.Button" data-dojo-props='onClick:function(){ doFind();}, value:"Search"'>Search</button> </p> </div> <div dojoType="dijit.layout.ContentPane" title="Results" id="results"> <div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'left'" style="width: 240px;" id="records"></div> </div> </div> </div> <div id="map" data-dojo-props="region:'center'" data-dojo-type="dijit.layout.ContentPane"></div> </div> </body> </html>
<table data-dojo-type="dojox.grid.DataGrid" data-dojo-id="grid" id="tgrid" data-dojo-props="rowSelector:'20px'"> <thead> <tr> <th field="Well_No">Well No</th> </tr> </thead> </table>
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd"> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8" /> <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9" /> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=yes"/> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.1/js/dojo/dijit/themes/soria/soria.css"/> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.1/js/dojo/dojox/grid/resources/Grid.css"/> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.1/js/dojo/dojox/grid/resources/soriaGrid.css"/> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.1/js/esri/dijit/css/Popup.css"/> <link rel="stylesheet" type="text/css" href="https://community.esri.com/css/beacon.css" /> <link rel="stylesheet" type="text/css" href="https://community.esri.com/css/tabs.css" /> <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } #map { padding:0; } </style> <script type="text/javascript"> dojoConfig = { parseOnLoad: true, locale: "en-gb" } </script> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.1"></script> <script type="text/javascript"> dojo.require("esri.map"); dojo.require("dijit.form.Button"); dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("dijit.layout.TabContainer"); dojo.require("dijit.Toolbar"); dojo.require("dojox.grid.DataGrid"); dojo.require("dojo.data.ItemFileReadStore"); dojo.require("dojo.data.ItemFileWriteStore"); dojo.require("esri.dijit.Print"); dojo.require("esri.tasks.find"); var app = {}; app.printUrl = "http://esweb1/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export Web Map Task"; //app.printUrl = "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export%20Web%20Map%20Task"; function init() { esri.config.defaults.io.proxyUrl = "/arcgisserver/proxy/proxy.ashx"; //esri.config.defaults.io.proxyUrl = "/~dswingley/esri_js/proxy/proxy.php"; app.map = new esri.Map("map", { extent: new esri.geometry.Extent({ "xmin": 19159196.0604085, "ymin": -5395900.2294505, "xmax": 19253117.1997641, "ymax": -5353486.89803372, "spatialReference": { "wkid": 102100 } }), logo: false, wraparound180: true }); var baseMapLayer = new esri.layers.ArcGISTiledMapServiceLayer("http://services.arcgisonline.com/ArcGIS/rest/services/Ocean_Basemap/MapServer"); app.map.addLayer(baseMapLayer); var dynamicMapServiceLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://arcgis.ecan.govt.nz/ArcGIS/rest/services/Public/Bus_Routes/MapServer", { "opacity": 0.8 }); app.map.addLayer(dynamicMapServiceLayer); dojo.connect(app.map, 'onLoad', function () { dojo.connect(dijit.byId('map'), 'resize', app.map, app.map.resize); var printMap = esri.request({ "url": app.printUrl, "content": { "f": "json" } }); printMap.then(print, error); }); } function print(p) { var template = new esri.tasks.PrintTemplate(); template.layout = "A4 Landscape"; template.format = "pdf"; template.layoutOptions = { "authorText": "", "copyrightText": "Copyright " + new Date().getFullYear(), "titleText": "Groundwater", "scalebarUnit": "Kilometers" }; printer = new esri.dijit.Print({ "map": app.map, "templates": [template], url: app.printUrl }, dojo.byId("print")); printer.startup(); } function doFind() { var s = dojo.byId("query").value var findParams = new esri.tasks.FindParameters(); var findTask = new esri.tasks.FindTask("http://arcgis.ecan.govt.nz/ArcGIS/rest/services/Public/Bus_Routes/MapServer"); findParams.layerIds = [1]; findParams.searchFields = ["RoadName"]; findParams.returnGeometry = true; findParams.outSpatialReference = app.map.spatialReference; findParams.searchText = s; findTask.execute(findParams, showResults); } function error(err) { alert("Error: " + err); } function showResults(results) { app.map.graphics.clear(); if (results.length > 0) { var items = dojo.map(results, function (result) { var graphic = result.feature; graphic.setSymbol(new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_CIRCLE, 14, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([6, 105, 140]), 1), new dojo.Color([6, 105, 140, 0.5]))); app.map.graphics.add(graphic); return graphic.attributes; }); var data = { 'identifier': 'OBJECTID', 'items': items } var store = new dojo.data.ItemFileReadStore({ data: data }); //destroy("grid"); //remove the grid so that the new results are bound fresh var grid = new dojox.grid.DataGrid({ 'id': 'grid', 'store': store, 'structure': [{ 'name': 'RoadName', 'field': 'RoadName', 'width': '200px' }], 'rowSelector': '0px' }); grid.placeAt("records"); grid.startup(); } else { alert("No results found matching your criteria."); } } dojo.ready(init); </script> </head> <body class="soria"> <div data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline'" style="width:100%; height:100%; margin:0;" id="workspace"> <div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'top'" id="header"> <div id="toolbar" data-dojo-type="dijit.Toolbar"> <div id="print"></div> </div> </div> <div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'left'" style="width: 240px;" id="side"> <div dojoType="dijit.layout.TabContainer" id="tabContainer" style="width: 100%; height: 100%;" tabPosition="top"> <div dojoType="dijit.layout.ContentPane" title="Main" id="main"> <h2>Search For...</h2> <div id="search"> <p>Look For:</span> <br/> <input type="text" id="query" style="width: 222px" /> </p> </div> <p>Look In: <br/> <select id="lookIn" style="width: 228px"> <option value="WN">Well Number</option> </select> </p> <p> <button data-dojo-type="dijit.form.Button" data-dojo-props='onClick:function(){ doFind();}, value:"Search"'>Search</button> </p> </div> <div dojoType="dijit.layout.ContentPane" title="Results" id="results"> <div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'left'" style="width: 240px;" id="records"></div> </div> </div> </div> <div id="map" data-dojo-props="region:'center'" data-dojo-type="dijit.layout.ContentPane"></div> </div> </body> </html>
