I've been creating a mashup of code that started with the LocalGovernment ParkFinder and some of the custom stuff I have done and am almost finished with the application. I just can't seem to get the basemap gallery to open fully when I click on the icon. I have referenced js files and a config file that is unchanged from the ParkFinder Template. Can anybody check my code to see what I might be missing? The initial basemap loads so I know it is reading correctly from the config file, it just doesn't give me the option to change it...Beating my head against the wall on this one.dojo.require("esri.tasks.locator");
dojo.require("dojo.number");
dojo.require("dijit.form.Button");
dojo.require("dijit.form.Textarea");
dojo.require("dijit.layout.BorderContainer");
dojo.require("dijit.layout.ContentPane");
dojo.require("esri.map");
dojo.require("esri.dijit.Popup");
dojo.require("esri.tasks.query");
dojo.require("esri.tasks.geometry");
dojo.require("esri.layers.FeatureLayer");
dojo.require("dijit.Dialog");
dojo.require("dijit.TooltipDialog");
dojo.require("dijit.form.ToggleButton");
dojo.require("dojox.widget.Standby");
dojo.require("esri.tasks.route");
var baseMapLayerCollection; //variable to store basemap collection
var map, locator;
var resizeTimer;
var identifyTask,identifyParams;
var defaultAddress; //variable for storing the default address
function init() {
var initExtent = new esri.geometry.Extent({
"xmin":-9261027.70119949,
"ymin":3341936.2768268585,
"xmax":-9021474.054553657,
"ymax":3479370.053683658,
"spatialReference":{"wkid":102100}});
esri.config.defaults.io.proxyUrl = "proxy.ashx"; //Setting to use proxy file
esriConfig.defaults.io.alwaysUseProxy = false;
esriConfig.defaults.io.timeout = 180000; //ersi request timeout value
dojo.connect(window, "onresize", function () {
if (map) {
map.resize();
map.reposition();
//Read Data from Config File
dojo.xhrGet({
url: "Config.txt",
handleAs: "json",
preventCache: true,
load: function (responseObject, ioArgs) {
dojo.connect(dijit.byId('imgHelp'), "onClick", function () {
window.open(helpFileURL, "helpwindow");
dijit.byId('imgHelp').attr("checked", false);
helpFileURL = responseObject.HelpFileUrl;
dojo.byId('imgApp').src = responseObject.ApplicationImage;
dojo.byId('lblAppName').innerHTML = responseObject.ApplicationName;
baseMapLayerCollection = responseObject.BaseMapLayers;
CreateBaseMapComponent();
dojo.connect(map, "onLoad", MapInitFunction);
customMouseHandler.addEvent(dojo.byId('divContainer'), 'mouseleave', HideBaseMapWidget, false);
customMouseHandler.addEvent(dojo.byId('divAppContent'), 'mouseleave', HideApplicationShareWidget, false);
//setup the popup window
var popup = new esri.dijit.Popup({
fillSymbol: new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255,0,0]), 2), new dojo.Color([255,255,0,0.25]))
}, dojo.create("div"));
map = new esri.Map("map",{
logo:false,
infoWindow:popup,
extent:initExtent
dojo.connect(map,"onLoad",mapReady);
//Add the imagery layer to the map. View the ArcGIS Online site for services http://arcgisonline/home/search.html?t=content&f=typekeywords:service
var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://services.arcgisonline.com/ArcGIS/rest/services/USA_Topo_Maps/MapServer");
map.addLayer(basemap);
var landBaseLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://gisdev2/arcgis/rest/services/Basemaps/GeneralPurpose/MapServer",{opacity:0.75});
map.addLayer(landBaseLayer);
var operationalLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://gisdev2:6080/arcgis/rest/services/Dynamic/SurveyBenchmarks/MapServer", {"opacity":1});
map.addLayer(operationalLayer);
function mapReady(map){
dojo.connect(map,"onClick",executeIdentifyTask);
//create identify tasks and setup parameters
identifyTask = new esri.tasks.IdentifyTask("http://gisdev2:6080/arcgis/rest/services/Dynamic/SurveyBenchmarks/MapServer");
identifyParams = new esri.tasks.IdentifyParameters();
identifyParams.tolerance = 5;
identifyParams.returnGeometry = true;
identifyParams.layerIds = [0,2];
identifyParams.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_ALL;
identifyParams.width = map.width;
identifyParams.height = map.height;
//resize the map when the browser resizes
dojo.connect(dijit.byId('map'), 'resize', map,map.resize);
locator = new esri.tasks.Locator("http://tasks.arcgis.com/ArcGIS/rest/services/WorldLocator/GeocodeServer");
dojo.connect(locator, "onAddressToLocationsComplete", showResults);
function locate() {
map.graphics.clear();
var address = {"SingleLine":dojo.byId("address").value};
locator.outSpatialReference= map.spatialReference;
var options = {
address:address,
outFields:["Loc_name"]
locator.addressToLocations(options);
function showResults(candidates) {
var candidate;
var symbol = new esri.symbol.SimpleMarkerSymbol();
var infoTemplate = new esri.InfoTemplate("Location", "Address: ${address}<br />Score: ${score}<br />Source locator: ${locatorName}");
symbol.setStyle(esri.symbol.SimpleMarkerSymbol.STYLE_CIRCLE);
symbol.setColor(new dojo.Color([153,0,51,0.75]));
var geom;
dojo.every(candidates,function(candidate){
console.log(candidate.score);
if (candidate.score > 80) {
console.log(candidate.location);
var attributes = { address: candidate.address, score:candidate.score, locatorName:candidate.attributes.Loc_name };
geom = candidate.location;
var graphic = new esri.Graphic(geom, symbol, attributes, infoTemplate);
//add a graphic to the map at the geocoded location
map.graphics.add(graphic);
//add a text symbol to the map listing the location of the matched address.
var displayText = candidate.address;
var font = new esri.symbol.Font("12pt",esri.symbol.Font.STYLE_NORMAL, esri.symbol.Font.VARIANT_NORMAL,esri.symbol.Font.WEIGHT_BOLD,"Helvetica");
var textSymbol = new esri.symbol.TextSymbol(displayText,font,new dojo.Color("#666633"));
textSymbol.setOffset(0,8);
map.graphics.add(new esri.Graphic(geom, textSymbol));
return false; //break out of loop after one candidate with score greater than 80 is found.
if(geom !== undefined){
map.centerAndZoom(geom,16);
function executeIdentifyTask(evt) {
identifyParams.geometry = evt.mapPoint;
identifyParams.mapExtent = map.extent;
var deferred = identifyTask.execute(identifyParams);
deferred.addCallback(function(response) {
// response is an array of identify result objects
// Let's return an array of features.
return dojo.map(response, function(result) {
var feature = result.feature;
feature.attributes.layerName = result.layerName;
if(result.layerName === 'Control Corners'){
console.log(feature.attributes.NAME);
var template = new esri.InfoTemplate("",
"<b>Control Station:</b> <a target='_blank' href=http://gisdev2/surveybenchmarks/scans/${Corner Point Identifier}.pdf>${Corner Point Identifier}</a> <br><b>Point Type:</b> ${Corner Point Type} <br><b>Monument Type:</b> ${Monument Type} <br><b>Status:</b> ${Status}"
feature.setInfoTemplate(template);
return feature ;
// InfoWindow expects an array of features from each deferred
// object that you pass. If the response from the task execution
// above is not an array of features, then you need to add a callback
// like the one above to post-process the response and return an
// array of features.
map.infoWindow.setFeatures([ deferred ]);
map.infoWindow.show(evt.mapPoint);
dojo.addOnLoad(init);
